i want to delete autodesk revit uni schemas 2024.
flognaw00
flognaw00
i want to reinstall But i found out that i couldn't delete and reinstall because of that program. how do i delete that program??
caroline.gitonga
Greetings @flognaw00
This error is brought about my missing original installation files or contains damaged files. The schema folder contains files related to the processing of units in Revit. This folder must be present, and contain valid files in order for Revit to start properly. If this folder is missing, contains files not expected, or the files are damaged in some way, you will receive an error dialog and Revit will close. You must repair this condition in order to start RevitYou can try solve this by replacing the folder with the contents of the folder from contents of working Revit installation or you re-install Revit.
Kindly, refer to below resource links to help you troubleshoot the error:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/The-feature-you-ar...
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-3562A7E7-7112-4B6D-97F6-D922BACC0CDF
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/2022-How-to-Comple...
Carol Gitonga, Developer Advocacy and Support, ADN Open
