i want to check whether tag is present on door by api how should i checked?
prasannamurumkar
prasannamurumkar
i have collected doors present in my project by
FilteredElementCollector collector = new FilteredElementCollector(activeDoc, vp.ViewId).OfCategory(BuiltInCategory.OST_Doors).WhereElementIsNotElementType();
some doors has door tag on door i just wants to verify it how should i proceed?
aignatovich
Hi!
You can find all IndependentTag-s, presented in the document of OST_DoorTags category and all doors ids:
var collector = new FilteredElementCollector(doc);
var doorTagsIds = new HashSet<ElementId>(collector.OfClass(typeof(IndependentTag)).OfCategory(BuiltInCategory.OST_DoorTags).OfType<IndependentTag>().Select(x => x.GetTaggedLocalElement()?.Id).Where(x => x != null));
Then you can iterate your doors collection and check if doorTagsIds contains door.Id
prasannamurumkar
thank you for reply it is working fine by comparing each id in door with doortag.
prasannamurumkar
this collect door not doortag
able to collect door tag by this
 FilteredElementCollector Collector1 = new FilteredElementCollector(activeDoc, vp.ViewId).OfCategory(BuiltInCategory.OST_DoorTags).WhereElementIsNotElementType();
but now my problem is getting collection doorTags Ids.But to compare with doors ids are different than their tags.
So how do we get relation between element and element Tag?
So that able to verify whether element is contain tag or not?
jeremytammik
You can collect door elements on one hand, and independent tag elements on the other.
From the independent tag, you can get the door using TaggedLocalElementId:
https://apidocs.co/apps/revit/2019/759306d1-5168-ef9a-91e4-494c7eff0b5d.htm
To get the tag from the door, you can invert this relationship:
http://thebuildingcoder.typepad.com/blog/2008/10/relationship-in.html
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
