graphics yes/no parameter
graphics yes/no instance parameter reverts to on when using revit 2018.3 but works fine when i use it on revit 2019. how do i fix this?
these are my parametersthese are my parametersthis is when i turn it offthis is when i turn it offand as soon as my pointer leaves the properties box it reverts to onand as soon as my pointer leaves the properties box it reverts to on
jeremytammik
Dear Christopher,
Thank you for your rather surprising report.
Unfortunately, this is not the best place to discuss such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
