i want Tag only the model I chose.
flognaw00
flognaw00
I don't want to put model tags all at once. I want to tag only the models I chose, is there a way?
Mohamed_Arshad
HI @flognaw00
This is not a place to ask Product related question, this forum is dedicated to Revit API based Queries :).
Kindly Check below link for Autodesk Forum List.
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
Kindly follow the steps:
1. Go to Manage Tab and Select Tag by Category.
2. Click on the Model which you need to tag. So this Tag by Category will create a Tag which you select.
Hope this will Helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
