I have two code samples and I don't know why one of them works and the other doesn't
Hi! I have rewritten the code snippet to solve my issue already, but I still can't find the reason why the previous one didn't work and it's driving me crazy 😄 so if anyone can find the issue, it would be amazing!
So I'm working a plug in that automatically sets area parameters and makes all the calculations for common areas, common area percentages, gross areas, etc.
I have created a simple method, that is searching for 'secondary' areas, whose area should be summed up with the main one. A good example would be this case:
which is a terrace, whose area should be added to the one of the ground floor apartment. In this case, the area of the terrace should summed up with the one of the apartment and written into this parameter:
So I first used this method:
public string calculatePrimaryArea()
string errorMessage = "";
List<string> missingNumbers = new List<string>();
transaction.Start();
foreach (Area mainArea in new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Areas).WhereElementIsNotElementType().ToList())
mainArea.LookupParameter("A Instance Gross Area").Set(mainArea.LookupParameter("Area").AsDouble());
foreach (Area secondaryArea in new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Areas).WhereElementIsNotElementType().ToList())
bool wasfound = false;
if (secondaryArea.LookupParameter("A Instance Area Primary").HasValue && secondaryArea.LookupParameter("A Instance Area Primary").AsString() != "" && secondaryArea.Area != 0)
if (secondaryArea.LookupParameter("A Instance Area Primary").AsString() == mainArea.LookupParameter("Number").AsString())
double sum = mainArea.LookupParameter("A Instance Gross Area").AsDouble() + secondaryArea.LookupParameter("Area").AsDouble();
bool wasSet = mainArea.LookupParameter("A Instance Gross Area").Set(sum);
wasfound = true;
// test
errorMessage += $"An area of: {secondaryArea.LookupParameter("Area").AsDouble()/areaConvert} is added to the one of Area Number: {mainArea.Number}, " +
$"whioch is at the moment: {mainArea.Area/areaConvert}! The total sum is {secondaryArea.LookupParameter("Area").AsDouble() / areaConvert + mainArea.Area / areaConvert}\n" +
$"calculated sum = {sum/areaConvert}\ncalculated sum in imperial = {sum}\nwasSet = {wasSet}\n" +
$"value for A Instance Gross Area after being set: = {mainArea.LookupParameter("A Instance Gross Area").AsDouble()}\n" +
$"the secondary Area object, added to the main one, has a number {secondaryArea.Number} and an Id: {secondaryArea.Id}\n\n";
// test
if (!wasfound && !missingNumbers.Contains(secondaryArea.LookupParameter("Number").AsString()))
missingNumbers.Add(secondaryArea.LookupParameter("Number").AsString());
errorMessage += $"Грешка: Area {secondaryArea.LookupParameter("Number").AsString()} / id: {secondaryArea.Id} / Посочената Area е зададена като подчинена на такава с несъществуващ номер. Моля, проверете го и стартирайте апликацията отново\n";
transaction.Commit();
return errorMessage;
As you can see, I have created a very informative report message in order to check if everything is alright. I would then set the parameter value to 0 and run the plugin:
Based on that, it seems that everything should be alright and even the parameter value, when read directly from the area instance, should be properly set:
However, when you select the area in Revit, the value of the parameter seems to somehow have reverted back to its previous value 😄
If I then write the method in this way:
foreach (Area secArea in new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Areas).WhereElementIsNotElementType().ToList())
if (secArea.LookupParameter("A Instance Area Primary").AsString() == mainArea.LookupParameter("Number").AsString() && secArea.LookupParameter("A Instance Area Primary").HasValue && secArea.Area != 0)
double sum = mainArea.LookupParameter("A Instance Gross Area").AsDouble() + secArea.LookupParameter("Area").AsDouble();
if (secArea.LookupParameter("A Instance Area Primary").HasValue && secArea.LookupParameter("A Instance Area Primary").AsString() != "" && secArea.Area != 0)
bool wasFound = false;
if (secArea.LookupParameter("A Instance Area Primary").AsString() == mainArea.LookupParameter("Number").AsString())
wasFound = true;
if (!wasFound && !missingNumbers.Contains(secArea.LookupParameter("Number").AsString()))
missingNumbers.Add(secArea.LookupParameter("Number").AsString());
errorMessage += $"Грешка: Area {secArea.LookupParameter("Number").AsString()} / id: {secArea.Id} / Посочената Area е зададена като подчинена на такава с несъществуващ номер. Моля, проверете го и стартирайте апликацията отново\n";
And now it actually works:
I just don't see any essential difference between the two and I would not get a proper nights sleep until I find out why the first one didn't work 😄
