Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
I am trying to create an arch and I am getting a circle.
6 REPLIES 6
barakSRXCH
181 Views, 6 Replies
I am trying to create an arch and I am getting a circle. what am I doing wrong?
the code:  arch = Arc.Create(
new XYZ(item.start[0] * Common.METER_TO_FEET + base_point.X, item.start[1] * Common.METER_TO_FEET + base_point.Y, 0),
new XYZ(item.end[0] * Common.METER_TO_FEET + base_point.X, item.end[1] * Common.METER_TO_FEET + base_point.Y, 0),
new XYZ(item.middle[0] * Common.METER_TO_FEET + base_point.X, item.middle[1] * Common.METER_TO_FEET + base_point.Y, 0));
w = Wall.Create(doc, arch, wall.Id, levelId, Common.WALL_HEIGHT * Common.METER_TO_FEET, 0.0, false, false);
thanks for your help!
6 REPLIES 6
Yien_Chao
in reply to: barakSRXCH
barakSRXCH
I am sorry, I didn't understand. When I created the Arc, it wasn't supposed to be Arc.Create(end0, end1, pointOnCurve)?
barakSRXCH
in reply to: Yien_Chao
What a, I suppose to do with the GetEndPoint(). I just started to work with Revit, so please be patient with me.
can you give an actual example?
Yien_Chao
my bad. i think the endpoint cant be set.
but you can create your arc at least with 3 methods
https://www.revitapidocs.com/2022/37b85ab9-0840-97e9-31b4-a0699e99f132.htm
if you dont want a circle, try with :
Create( XYZ end0, XYZ end1, XYZ pointOnArc
hope that could help
barakSRXCH
It is exactly what I used
RPTHOMAS108
Your first step is to look at the numbers for start/end/middle. No real point answering a question where the most likely error is the numbers you are not providing in the question (other than to say provide the numbers).
I prefer the other two overloads to be honest.
Would also do the conversion from m to ft elsewhere, likelihood is you have two points close together.
Autodesk Customer Advisory Groups
Rail Community
