How to Use NewFamilyInstance on Opposite Side of Wall for Wall-Mounted Families
I made a simple wall-mounted family using the "Generic Model wall based.rft" template. The family is just an extrusion attached to the top side of the wall as viewed in the Ref. Level
wall-mounted-box.rfa:
I want to import this wall-mounted-box.rfa into another Family (I will call this import.rfa) that also uses the "Generic Model wall based.rft" template. I want to place the box on the opposite side of the wall though, like the picture below. I can do this easily within the Revit UI. But I can't figure it out with the Revit API.
import.rfa:
Here is code showing the methods I've tested
string templateFileName =
    @"C:\ProgramData\Autodesk\RAC 2016\Family Templates\English_I\Generic Model wall based.rft";
Document document = uiApplication.Application.NewFamilyDocument(templateFileName);
Family family;
using (Transaction transaction = new Transaction(document))
    transaction.Start("Load Family");
    document.LoadFamily(@"...\wall-mounted-box.rft", out family);
    transaction.Commit();
FamilySymbol symbol = document.GetElement(family.GetFamilySymbolIds().First()) as FamilySymbol;
FilteredElementCollector wallCollector = new FilteredElementCollector(document);
Wall wall = wallCollector.OfClass(typeof(Wall)).FirstElement() as Wall;
    tx.Start("Instantiate Family");
    symbol.Activate();
    // METHOD 1: Default wall host
    FamilyInstance familyInstance = document.FamilyCreate.NewFamilyInstance(new XYZ(0,0,0), symbol, wall, StructuralType.NonStructural);
    // METHOD 2: try setting referenceDirection
    document.FamilyCreate.NewFamilyInstance(new XYZ(0,0,0), symbol, new XYZ(0,-1,0), wall, StructuralType.NonStructural);
// METHOD 3: Try flipping the FamilyInstance
familyInstance.flipFacing();
// setup for METHOD 4/5 Reference reference = HostObjectUtils.GetSideFaces(wall, ShellLayerType.Interior).First(); // METHOD 4: use reference to face with method from this site // http://adndevblog.typepad.com/aec/2015/06/revitapi-create-familyinstance-on-a-wall-face.html document.FamilyCreate.NewFamilyInstance(reference, new XYZ(0, 0, 0), new XYZ(0, -1, 0), symbol); // METHOD 5: Get the face to place on // I just grabbed the index-2 face arbitrarily since this method doesn't work anyways Options opt = new Options(); opt.ComputeReferences = true; Face face = (wall.get_Geometry(opt).First() as Solid).Faces.get_Item(2); document.FamilyCreate.NewFamilyInstance(face, new XYZ(0, 0, 0), new XYZ(0, -1, 0), symbol); tx.Commit(); } SaveAsOptions saveAsOptions = new SaveAsOptions(); saveAsOptions.OverwriteExistingFile = true; document.SaveAs(@"...\import.rft", saveAsOptions);
METHOD 1 and METHOD 2 just places the box on the default side of the wall which is the top. Looks exactly like the wall-mounted-box.rfa picture.
METHOD 3 doesn't work because familyInstance.CanFlipFacing is false.
Here are the properties I grabbed from FamilyInstances I creating using the Revit UI.
default orientation on top of wall:
2017-07-18
opposite orientation on bottom of wall:
2017-07-18
METHOD 5 says "Family cannot be placed as hosted on an input face reference, because its FamilyPlacementType is not WorkPlaneBased"
METHOD 4 also says that FamilyPlacementType is not WorkPlaneBase.
How do I do this?
FAIR59
You can mirror the family twice, first  X-axis, then Y-axis.
			FamilyInstance temp=null;
			using (Transaction t = new Transaction(doc,"place instance"))
				t.Start();
			using (SubTransaction st = new SubTransaction(doc))
				st.Start();
				temp = doc.FamilyCreate.NewFamilyInstance(new XYZ(0,0,0), symb, new XYZ(1,0,0), wall,StructuralType.NonStructural);
				st.Commit();
			IList<ElementId> mirrored = null;
				st.Start();
				mirrored = ElementTransformUtils.MirrorElements(doc,new List<ElementId>(){temp.Id},new Plane(XYZ.BasisY,XYZ.Zero),true);
			 	doc.Delete(temp.Id);
				st.Commit();
			List<ElementId> mirrored2 = new List<ElementId>();
			foreach (var id in mirrored)
				Element e = doc .GetElement(id);
				if (e==null) continue;
				mirrored2.Add(id);
				st.Start();
				mirrored = ElementTransformUtils.MirrorElements(doc,mirrored2,new Plane(XYZ.BasisX,XYZ.Zero),true);
			 	doc.Delete(mirrored2);
				st.Commit();
			t.Commit();
Thanks Fair59, it works. I'm just wondering, how come you have to check for e==null? Will it ever be null from the output of MirrorElements()? You are just trying to create a copy of mirrored in mirrored2 right?
FAIR59
It seems I didn't clean up the code sufficiently, that is a remnant of some test code. Just making a copy will work.
Annonymous24
I am facing the issue, Can't place inserts outside of hosts. These elements won't be copied.
I am using face top edge then get its 1st endpoint for placement.
