How to use GetGeometryObjectFromReference() if Reference in rvt-link
Bogdan1896
Bogdan1896
Part of code on Python:
reference_intersector = ReferenceIntersector(
    ElementId(2471),
    FindReferenceTarget.Face,
    doc.ActiveView) #ElementId refers to RevitLinkInstance
reference_intersector.FindReferencesInRevitLinks = True
floors_refs = [i.GetReference() for i in reference_intersector.Find(point,point2)] #Getting Reference from ReferenceWithContext
linkdoc = doc.GetElement(ElementId(2471)).GetLinkDocument()
floors = [linkdoc.GetElement(i.LinkedElementId) for i in floors_refs] #Getting floor element from link
#Case 1:
face = floors[0].GetGeometryObjectFromReference(floors_refs[0]) #Exception: The id of this element is not same as that referenced by reference
Case 2:
link_inst = doc.GetElement(ElementId(2471))
face = floors[0].GetGeometryObjectFromReference(floors_refs[0].CreateLinkReference(link_inst))#EnvironmentError: System.Runtime.InteropServices.SEHException (0x80004005)
 What am I doing wrong ? In project only one lighting fixture and one floor. This "algorithm" works in a project without linked files
RPTHOMAS108
Reference.CreateReferenceInLink
not
Reference.CreateLinkReference
i.e. you want to take a reference obtained in the host document where ReferenceIntersector was used and find the equivalent to that in the linked document where you query the element geometry.
The other option you used is the reverse of that i.e. to take a reference in the link and create a version of that in the host for dimensioning or hosting elements.
Reference.CreateReferenceInLink will only work if the Reference was obtained from a link to start with i.e. it inherently has the link information within the original reference.
Bogdan1896
Thanks for the answer
Yes, I also tried this option
refs = [i.GetReference().CreateReferenceInLink() for i in reference_intersector.Find(point,point2)]
and get error:
Exception: A managed exception was thrown by Revit or by one of its external applications.
Script Executor Traceback:
Autodesk.Revit.Exceptions.InternalException: A managed exception was thrown by Revit or by one of its external applications.
в Autodesk.Revit.DB.Reference.CreateReferenceInLink()
в Microsoft.Scripting.Interpreter.FuncCallInstruction`2.Run(InterpretedFrame frame)
в Microsoft.Scripting.Interpreter.Interpreter.Run(InterpretedFrame frame)
в Microsoft.Scripting.Interpreter.LightLambda.Run3[T0,T1,T2,TRet](T0 arg0, T1 arg1, T2 arg2)
в System.Dynamic.UpdateDelegates.UpdateAndExecute2[T0,T1,TRet](CallSite site, T0 arg0, T1 arg1)
в Microsoft.Scripting.Interpreter.DynamicInstruction`3.Run(InterpretedFrame frame)
в Microsoft.Scripting.Interpreter.LightLambda.Run2[T0,T1,TRet](T0 arg0, T1 arg1)
в IronPython.Compiler.PythonScriptCode.RunWorker(CodeContext ctx)
в PyRevitLabs.PyRevit.Runtime.IronPythonEngine.Execute(ScriptRuntime& runtime)
I guess the reference have information about link because:
refs = [i.GetReference().LinkedElementId for i in reference_intersector.Find(point,point2)]
Return Id of floor
RPTHOMAS108
I followed the process through and below code works ok for me.
I think you just need to break it down into more lines and drop the iteration of 'i' part to understand where the actual issue is.
Public Function Obj_220826a(commandData As ExternalCommandData, ByRef message As String, elements As ElementSet) As Result
        Dim IntUIApp As UIApplication = commandData.Application
        Dim IntUIDoc As UIDocument = commandData.Application.ActiveUIDocument
        Dim IntDoc As Document = IntUIDoc.Document
        Dim AcView As View3D = TryCast(IntUIDoc.ActiveGraphicalView, View3D)
        If AcView Is Nothing Then Return Result.Cancelled Else
        Dim Ri As New ReferenceIntersector(IntUIApp.ActiveUIDocument.ActiveGraphicalView)
        Ri.FindReferencesInRevitLinks = True
        Ri.TargetType = FindReferenceTarget.Face
        Dim RwithC As ReferenceWithContext = Ri.FindNearest(XYZ.Zero, XYZ.BasisX)
        If RwithC Is Nothing Then Return Result.Cancelled Else
        Dim Ref As Reference = RwithC.GetReference
        Dim El As RevitLinkInstance = TryCast(IntDoc.GetElement(Ref), RevitLinkInstance)
        If El Is Nothing Then Return Result.Cancelled Else
        Dim LnkDoc As Document = El.GetLinkDocument
        Dim R1 As Reference = Ref.CreateReferenceInLink
        Dim LnkEl As Element = LnkDoc.GetElement(R1)
        Dim Geom As GeometryObject = LnkEl.GetGeometryObjectFromReference(R1)
        Return Result.Succeeded
    End Function
Bogdan1896
So,
I don't not what's going on. I was trying to run python code in pyrevit, dynamo, sharp develop and get same error: "A managed exception was thrown by Revit or by one of its external applications."
I repeat my code on C# language and get this error. I give up))  Thaths for help )
Document doc = this.Document;
UIDocument uidoc = this;
XYZ point = uidoc.Selection.PickPoint();
XYZ point_high = new XYZ(point.X, point.Y, 20);
XYZ point_low = new XYZ(0,0,-1);
ReferenceIntersector reference_intersector = new ReferenceIntersector(
				(View3D)doc.ActiveView);
reference_intersector.FindReferencesInRevitLinks = true;
reference_intersector.TargetType = FindReferenceTarget.Face;
ReferenceWithContext ref_with_cont = reference_intersector.FindNearest(
				point_high,
				point_low);
Reference reference = ref_with_cont.GetReference();
Reference reference2 = reference.CreateReferenceInLink();
