Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to use BuiltInCategory.OST_Wall ?
2 REPLIES 2
2115 Views, 2 Replies
I have four structural walls in my project but given code showing zero. Where am I making mistake? However if I replace OST_Walls with OST_StructuralColumns, it works perfectly.  Also from where can I get description of all members of BuiltInCategory enum? Revit Api docs just provide members without details.
public void Trial1()
			Document doc = this.ActiveUIDocument.Document;
			string info = String.Empty;
			int a=0;
			foreach (Element e in new FilteredElementCollector(doc)
.OfClass(typeof(FamilyInstance))
.OfCategory(BuiltInCategory.OST_Walls)) { a++; } TaskDialog.Show("Count",a.ToString()); }
2 REPLIES 2
MarryTookMyCoffe
If you look for walls you write ofclass(Wall) not a familyInstance.
Try this, install revit look up and see there what object is which class.
do not worry it only gonna take Autodesk 5 years to fix bug
jeremytammik
Thanks to MarryTookMyCoffe for the helpful answer. This is the link to download and install RevitLookup:
https://github.com/jeremytammik/RevitLookup
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Autodesk Customer Advisory Groups
Rail Community
