How to use a parametrically modeled element in the API of a plugin in Revit
11:19 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everybody!
Hope you're fine!
I have already started programming a plugin in the API. In a part of this plugin, I'd like to import the parametrically modeled elements in the Revit family into the plugin and change their parameters using API.
For example, I have modeled a column parametrically in the Revit family manually; Now, I'd like to have a push-button that when users click on it, the modeled column is imported and its parameters can be accessed through the API (plugin).
Next, I'd like to adjust the parameters of the column through API and change its position in the active document.
I would be so happy if someone helps me; I really need it.
Kind regards,
Saeed.
