How to update progress bar simultaneously with some code execution
I creating a simple Addin for Revit for joining wall and column.
That addin contain form. When I click addin it display the windows form as I attached the image.
If I select  item wall and column from drop down list and click the button It join wall and column successfully and show message.For this is create a class name as WCjoin.cs.This class I call from form button click event.
But I dont want to do that I want progress bar which update the progress bar when class is executing and wall column is joining.
I write the code for that but it update the progress bar after class is executed.
This is the code:
Form Code:-
using System;
using System.Windows.Forms;
using Autodesk.Revit.UI;
namespace JoinGeometry
          [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
          public partial class AdvanceJoin : Form
                   ExternalCommandData commandData;
                  public AdvanceJoin(ExternalCommandData commandDatax)
                           commandData = commandDatax;
                           InitializeComponent();
                  private void AdvanceJoin_Load(object sender, EventArgs e)
                            comboBox1.Items.Add("Wall and Column");
                   private void button1_Click(object sender, EventArgs e)
                             progressBar1.Value = 0;
                             timer1.Stop();
                             timer1.Start();
                             if (comboBox1.SelectedItem == "Wall" && comboBox2.SelectedItem == "Column")
                                          try
                                                    WCjoin wcj = new WCjoin();
                                                    wcj.Execute(commandData);
                                                    label2.Text = "WALL COLUMN JOINED";
                                           catch (Exception g)
                                                     TaskDialog.Show("revit", "error is occured" + g);
                     private void timer1_Tick(object sender, EventArgs e)
                                     progressBar1.Increment(5);
Code :Class WCjoin.cs
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
                    [Transaction(TransactionMode.Manual)]
                    class WCjoin
                              bool check;
                              public Result Execute(ExternalCommandData commandData)
                                             UIApplication uiApp = commandData.Application;
                                             UIDocument uidoc = uiApp.ActiveUIDocument;
                                             Document doc = uidoc.Document;
                                             FilteredElementCollector collWalls = new FilteredElementCollector(doc, doc.ActiveView.Id);
                                             collWalls.OfClass(typeof(Wall));
                                             foreach (Wall w in collWalls)
                                                             FilteredElementCollector collColumnsOnThisWall = new FilteredElementCollector(doc, doc.ActiveView.Id);
                                                             collColumnsOnThisWall.OfClass(typeof(FamilyInstance));
                                                             collColumnsOnThisWall.OfCategory(BuiltInCategory.OST_StructuralColumns);
                                                             BoundingBoxXYZ bb = w.get_BoundingBox(doc.ActiveView);
                                                             Outline outline = new Outline(bb.Min, bb.Max);
                                                             BoundingBoxIntersectsFilter bbfilter =new BoundingBoxIntersectsFilter(outline);
                                                             collColumnsOnThisWall.WherePasses(bbfilter);
                                                             foreach (FamilyInstance column in collColumnsOnThisWall)
        using (Transaction t = new Transaction(doc, "Join All Walls/Column"))
        t.Start();
        check = JoinGeometryUtils.AreElementsJoined(doc, w, column);
        if (check == true)
        else
        JoinGeometryUtils.JoinGeometry(doc, w, column);
        t.Commit();
                                       return Result.Succeeded;
I want to update progress bar while WCjoin class is executing and after the class WCjoin has been successfully completed the progress bar has been stoped with full 100%
What I should do for achieveing my target.
