how to understand revit api geometry ?
kapitalaudio1234
kapitalaudio1234
hello everyone , i am a complete beginner and was trying to understand the basics of geometry in the revit api ( what are solids, meshes, faces, xyz class , how to extract geometry from elements . but i am confused because i cannot find a starting point, can anyone give me advice please which path.websites.courses i should follow would be so grateful
i am wondering is there something like the dynamo primer?
Mohamed_Arshad
Hi @kapitalaudio1234
Welcome to Revit API, Autodesk has provided proper documentation on the Geometry so you can start by referring the below link which is exactly like Dynamo Primer
Help | Geometry | Autodesk
Once you gone through all the concepts, you must practice it and visualize it. To do that you can use the Revit API SDK Samples, Open samplecontent.html doc from the samples.
In-Between practice if you got any queries you can refer to the Jeremy Tammik blog
The Building Coder: Geometry
Hope this will Helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
kapitalaudio1234
thank you alot thats perfect
