How to split selected spline from the picked point
kite15
510 次查看
4 条回复
1 条消息(共 5 条)
kite15
Can anyone help NurbSpline a picked spline in Revit 2021?
Any idea about how I can start to split the picked one
Thank you
0 个赞
已接受的解答 (1)
511 次查看
4 条回复
回复 (4)
2 条消息(共 5 条)
jeremy_tammik
Use the original spline data to create two new separate splines.
0 个赞
3 条消息(共 5 条)
kite15
Thank you Mr. Jeremy,
Can you please, suggest how I can adjust the vertices according to the current Spline form?
For example, if I like to split this into three parts.
Kinly, give some more light on this.
Thanks.
0 个赞
4 条消息(共 5 条)
RPTHOMAS108
已接受的解答
You can change the bound limits the downside is the control points remain the same.
Below is for detail curves but same applies to model curves.
Private Class RT_SelCurveElement
        Implements Autodesk.Revit.UI.Selection.ISelectionFilter
        Public Function AllowElement(elem As Element) As Boolean Implements Selection.ISelectionFilter.AllowElement
            Return TypeOf elem Is DetailCurve
        End Function
        Public Function AllowReference(reference As Reference, position As XYZ) As Boolean Implements Selection.ISelectionFilter.AllowReference
            Return True
        End Function
    End Class
    Private Function Obj_231109a(ByVal commandData As Autodesk.Revit.UI.ExternalCommandData,
ByRef message As String, ByVal elements As Autodesk.Revit.DB.ElementSet) As Result
        Dim UIApp As UIApplication = commandData.Application
        Dim UIDoc As UIDocument = commandData.Application.ActiveUIDocument
        If UIDoc Is Nothing Then Return Result.Cancelled Else
        Dim Doc As Document = UIDoc.Document
        Dim R As Reference = Nothing
        Try
            R = UIDoc.Selection.PickObject(Selection.ObjectType.PointOnElement, New RT_SelCurveElement)
        Catch ex As Exception
        End Try
        Dim crvEl As CurveElement = Doc.GetElement(R)
        Dim Crv As Curve = crvEl.GeometryCurve
        Dim IR As IntersectionResult = Crv.Project(R.GlobalPoint)
        Dim Param As Double = IR.Parameter
        Dim crv0 = Crv.Clone
        Dim crv1 = Crv.Clone
        crv0.MakeBound(crv0.GetEndParameter(0), Param)
        crv1.MakeBound(Param, crv1.GetEndParameter(1))
        Using Tx As New Transaction(Doc, "Split detail curve")
            If Tx.Start = TransactionStatus.Started Then
                Dim DC0 As DetailCurve = Doc.Create.NewDetailCurve(UIDoc.ActiveGraphicalView, crv0)
                Dim DC1 As DetailCurve = Doc.Create.NewDetailCurve(UIDoc.ActiveGraphicalView, crv1)
                DC0.LineStyle = crvEl.LineStyle
                DC1.LineStyle = crvEl.LineStyle
                Doc.Delete(crvEl.Id)
                Tx.Commit()
            End If
        End Using
        Return Result.Succeeded
    End Function
5 条消息(共 5 条)
kite15
Awesome.. Thank you .. its working fine
0 个赞
