How to show Warning Errors when use doc.Delete
Hi everyone,
I'm a newbie in Revit API. My idea is to delete all selection element, if there is any warning -> rollback. Below is my code.
List<ElementId> idList = uidoc.Selection.GetElementIds().ToList();
            foreach (ElementId id in idList)
                using (Transaction trans = new Transaction(doc, "Delete"))
                    trans.Start();
                    FailureHandlingOptions failOpt = trans.GetFailureHandlingOptions();
                    failOpt.SetFailuresPreprocessor(new WarningDiscard());
                    trans.SetFailureHandlingOptions(failOpt);
                    try
                        doc.Delete(id);
                    catch
                        continue;
                    trans.Commit();
public class WarningDiscard : IFailuresPreprocessor
        FailureProcessingResult
          IFailuresPreprocessor.PreprocessFailures(FailuresAccessor failuresAccessor)
            IList<FailureMessageAccessor> fmas = failuresAccessor.GetFailureMessages();
            if (fmas.Count > 0)
                return FailureProcessingResult.ProceedWithRollBack;
            return FailureProcessingResult.Continue;
My problem is: when I delete manually (by using Delete keyboard), Revit showed:
But when I use doc.Delete(id), Revit doesn't show any warning.
What I have to do? Please suggest.
Thank you!
still waiting for the solution...
adam.krug
I would skip the below part. Then warnings should be displayed for a user.
Hi Adam,
I tried it but Revit still delete without any Warnings.
