How to set tab order in dialog box on revit
  [DllImport("user32.dll", SetLastError = true)]
        static extern IntPtr SetParent(IntPtr hWndChild, IntPtr hWndNewParent);
        /// <summary>
        /// Method  form Making the form as modeless dialog
        /// </summary>
        /// <param name="p"></param>
        public static void CreateModelessDialog(Presentation.GS_Export p)
            try
                IntPtr h = new IntPtr();
                if (null == _hWndRevit)
                    Process[] processes = Process.GetProcessesByName("Revit");
                    if (0 < processes.Length)
                        h = processes[0].MainWindowHandle;
                        _hWndRevit = new WindowHandle(h);
                SetParent(p.Handle, h);
                p.Show(_hWndRevit);
                //p.ShowDialog(_hWndRevit);
                //Application.Run(p);
                Flag = false;
            catch (Exception Ex)
im not able to use tab key in dialog box .if i use this code. how to set tab order for modeless dialoge box in revit ? can anyone hv sample code.
Joe.Ye
This is not an issue about Revit or Revit API.
All modeless dialog displayed from a dll has this problem.
A page in Microsft website has more information and solution about this.
http://support.microsoft.com/kb/233263
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
