How to set "Title on Sheet" property for a Drafting View...
Fred_Schreck
Fred_Schreck
Hello:
I'm writing a VSTA macro to create a new drafting view. I want to be able to specify the view name, scale, and "Title on Sheet" parameters for the drafting view. Here's the code so far:
Private Sub glNewView(ByVal strViewName As String, ByVal strSheetName As String, ByVal intViewScale As Integer)
Dim myDraftingView As ViewDrafting = Me.Create.NewViewDrafting()
myDraftingView.ViewName = strViewName
myDraftingView.Parameter("VIEWPORT_SHEET_NAME").SetValueString(strSheetName)
myDraftingView.Scale = intViewScale
End Sub
In VSTA IDE reports that 'Parameter' is not a member of 'Autodesk.Revit.Elements.ViewDrafting'
How can I set the "Title on Sheet" parameter?
Thanks in advance,
Fred Schreck
San Francisco, CA
Hi Fred try this, it works for me:
myDraftingView.Parameter("Title on Sheet").Set(strSheetName)
regards
Ed
J33C316
This no longer works in Revit 2019. Anyone know how to get the "Title on Sheet" parameter value? It doesn't appear to be a BuiltInParameter. Thanks.
joshua.lumley
 uidoc.ActiveView.get_Parameter(BuiltInParameter.VIEW_DESCRIPTION).Set("Hello World");
peteregan
Easily discovered with Revit Lookup:
J33C316
Thanks. I'd accept this as the solution but the button is missing for some reason.
