How to set "Shared Site" for linked Revit model
AnatolyCEL
Message 1 of 8
AnatolyCEL
How to change "Shared Site" parameter for linked Revit model with API. I need to set <Not Shared> value.
Anatoly.
Replies (7)
Message 2 of 8
jeremytammik
Message 3 of 8
evgeny.kurbatov
@jeremytammik
Thank you for the respond. Reading the link I found this:
You cannot establish a shared-coordinates relationship with a link instance via the API. If the link is already using shared coordinates, then moving the survey point will move the link.
I understand that that the requested action cannot be done with Revit API. Correct me if i am wrong.
Is it possible to do that with Dynamo?
Message 4 of 8
jeremytammik
Dynamo wraps the Revit API and uses that and nothing else to interact with Revit.
Therefore, if this functionality is not supported by the API, Dynamo cannot support it either.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 5 of 8
AnatolyCEL
Hello Jeremy,
Will there be a realization of this feature in future versions?
Anatoly.
Message 6 of 8
jeremytammik
Dear Anatoly,
Check it yourself in the Revit Idea Station.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 7 of 8
MANZNHYQ
Have I understood this post correctly, that it's not possible to set the position of a linked project (analog to this function in the UI)? This function would be essential for the addin I'm developing.
Message 8 of 8
lukasz_koc2
Hi!,
did you find a solution for this issue?
