How to set and retrieve a size of created ducts with API?
nur91m
nur91m
Hi everyone!
How to set and retrieve a size(diameter of round ducts, height and width of rect ducts) of created ducts with API?
I'm using VS C#2010.
Joe.Ye
You can get the duct's shape from the duct's parameter.
For the round duct, you can get and set the duct diameter via this parameter: RBS_CURVE_DIAMETER_PARAM
for the rectangle duct, get and set the height and width via these two parameters:
Width: RBS_CURVE_WIDTH_PARAM
Height: RBS_CURVE_HEIGHT_PARAM
For example, you want to increase a round diameter by 10mm. Here is the code fragment.
<code>
Parameter param = duct.get_Parameter(BuiltInParameter.RBS_CURVE_DIAMETER_PARAM);
double diameter = param.AsDouble();
param.Set(diameter+10);
<code>
Hope this helps!
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
nur91m
Yes, it works. )) Thanks for your help Joe.Ye.
seyedehmaedeh_aghili
Is it possible to increase the input parameter of duct cross section? since in my case it's not recatngular or oval, it needs more parameter to be defined.
