You can get the duct's shape from the duct's parameter.
For the round duct, you can get and set the duct diameter via this parameter: RBS_CURVE_DIAMETER_PARAM
for the rectangle duct, get and set the height and width via these two parameters:
Width: RBS_CURVE_WIDTH_PARAM
Height: RBS_CURVE_HEIGHT_PARAM
For example, you want to increase a round diameter by 10mm. Here is the code fragment.
<code>
Parameter param = duct.get_Parameter(BuiltInParameter.RBS_CURVE_DIAMETER_PARAM);
double diameter = param.AsDouble();
param.Set(diameter+10);
<code>
Hope this helps!
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
