How to select a single element in Revit? C#
rita.aguiar
rita.aguiar
I have tried with:
uidoc.Selection.SetElementIds(elementid);
SetElementIds requires an ICollector<ElementId> as argument and so I don't know how to only select a single element through its id, of type ElementId.
Any help would be appretiated.
jeremytammik
Create a new, empty, list of element ids, i.e., an `IList<ElementId>`, add your one single element to that, and pass it in as an argument to SetElementIds.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
so-chong
Did you try to use the PickObject Method to select one object?
Something like this
ElementId elementid = null;
elementid = uidoc.Selection.PickObject(ObjectType.Element, "Select element or ESC to reset the view").ElementId;
NinovSM
Hello, do you know similar method for highligthing like SetElementIds but for subelements?
jeremy_tammik
Nope, sorry, I do not believe this exists.
You could submit a wish list item for this in the Revit Idea Station.
You could also try to highlight something using AVF or direct context 3D, cf.,
https://thebuildingcoder.typepad.com/blog/2020/10/onbox-directcontext-jig-and-no-cdn.html#3
Walker.Jack
Observer
Observer
Does the SetElements retrieve the elements from the database and highlight them in the UI or does it simply retrieve the elements from the database?
jeremy_tammik
It does not retrieve elements from the database.
It does select and highlight them in the UI.
For an example, please refer to the official Revit SDK and the SDK sample DirectionCalculation / FindSouthFacingWalls.
