How to Save the Rendered Image to file by RevitAPI?
I want to save the Rendered image after rendering, but How to achieve the "Export" function in Rendering Dialog by Revit API?
dialog of renderdialog of render
Hei @Anonymous
Which of the built in commands could you successfully call by now from the API?
I found these three:
Maybe call them to see if they export it already?
I found also a lot of built in export commands, maybe one of them helps you:
I have tried the above command, but they are not effective
@Anonymous
Maybe the customexporter class would help?
