How to retrieve detail Item Geometry?
jmyr
jmyr
Options options = new Options();
                            GeometryElement geoEle = guidline.get_Geometry(options);
                            foreach (var subEle in geoEle)
                                Line line = subEle as Line;
                                if (line!= null)
                                    point1 = line.GetEndPoint(0);
                                    point2 = line.GetEndPoint(1);
Hi Guys,
I have detail item (Line based family), just a simple line inside but I'm having trouble getting its geometry. Any ideas?
below code is not working.
RPTHOMAS108
Detail items are view specific so Options.View would require a view to be set for it.
Since it is a family instance the top level item will be a GeometryInstance from which you can then get the instance or symbol geometry.
You can review this in RevitLookup using 'View = ActiveView' branch vs 'View = null'.
jmyr
Thanks @RPTHOMAS108 not sure exactly what do you mean, i tried below but still getting null
                            options.View = _doc.ActiveView;
                            XYZ point1 = null;
                            XYZ point2 = null;
                            List<GeometryInstance> ginsList = guidline.get_Geometry(options).Where(o => o is GeometryInstance).Cast<GeometryInstance>().ToList();
                            foreach (GeometryInstance gins in ginsList)
                                foreach (GeometryObject ge in gins.GetSymbolGeometry())
                                    Line line = ge as Line;
                                    if (line != null)
RPTHOMAS108
From looking at your code I don't see anything obviously wrong. Make sure 'Line' is coming from the Revit API namespace perhaps.
Is the active view the one that contains the element? Always best to use UIDocument.ActiveGraphicalView, since the project browser and other interface windows occasionally become the active view.
Using RevitLookup, below is what you should see for a line based detail item family symbol geometry (more common for me to use the instance geometry):
FrankHolidaytoiling
This is a bit late, however are you checking the geometry is a Line before accessing it?
if(x is Line) {then do stuff;}
