Hi I'm trying to find a way of reading the Number of MaximumBackups that is set in the SaveAsOptions
which is set in the UI here:-
I want to be able to check if a user has set this too low (ie 1).
Does anyone know if this is available in the API.
I know that the ability to set this was only added in Revit 2014, but I just want to read the current setting rather than change the value.
Thanks in advance
Solved by jeremytammik. Go to Solution.
Awesome, thanks Jeremy
I'm trying this in the python shell and when I got the first response below and then read the what's new in Revit 2014, I assumed that it was a read only property. Didn't think of instantiating a SaveAsOptions object first.
Thanks for the response
