hi,
on form load of settings, behind i want to select my ribbon button programmatically.
i tried IsActive, IsChecked and Highlight but it doesnt workout for me.
so is there a way i can do it...
Solved by jeremy_tammik. Go to Solution.
The official Revit API does not provide any such functionality, afaik.
Oh, actually, on second thoughts, one possibility is in fact supported:
If the ribbon button is connected with an external command, you can also launch that command programmatically:
