Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to place a face base family at column?
5 REPLIES 5
658 Views, 5 Replies
place a face base family at  wall  or  beam  is OK, but at column is wrong.
5 REPLIES 5
        private static void CreateInstancesOnHostFamilyFaces(FamilySymbol familySymbol, FamilyInstance hostInstance)
            var faces = GetSolids(hostInstance)
                .SelectMany(x => x.Faces.OfType<PlanarFace>());
            var doc = familySymbol.Document;
            using (var transaction = new Transaction(doc, "create families"))
                transaction.Start();
                if (!familySymbol.IsActive)
                    familySymbol.Activate();
                foreach (var planarFace in faces)
                    var faceBox = planarFace.GetBoundingBox();
                    var center = planarFace.Evaluate(0.5 * (faceBox.Max + faceBox.Min));
                    doc.Create.NewFamilyInstance(planarFace, center, XYZ.Zero, familySymbol);
                transaction.Commit();
        private static IEnumerable<Solid> GetSolids(Element element)
            var geometry = element
              .get_Geometry(new Options { ComputeReferences = true });
            if (geometry == null)
                return Enumerable.Empty<Solid>();
            return GetSolids(geometry)
                .Where(x => x.Volume > 0);
        private static IEnumerable<Solid> GetSolids(IEnumerable<GeometryObject> geometryElement)
            foreach (var geometry in geometryElement)
                var solid = geometry as Solid;
                if (solid != null)
                    yield return solid;
                var instance = geometry as GeometryInstance;
                if (instance != null)
                    foreach (var instanceSolid in GetSolids(instance.GetInstanceGeometry()))
                        yield return instanceSolid;
                var element = geometry as GeometryElement;
                if (element != null)
                    foreach (var elementSolid in GetSolids(element))
                        yield return elementSolid;
        public Autodesk.Revit.UI.Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet eleSet)
            Selection selection = cmdData.Application.ActiveUIDocument.Selection;
            m_doc = cmdData.Application.ActiveUIDocument.Document;
            FamilyInstance ins= null;
            try
                Reference selected = selection.PickObject(ObjectType.Element, "select:");
                Element elemPick = m_doc.GetElement(selected.ElementId);
                ins = elemPick as FamilyInstance;
            catch (System.Exception)
                return Result.Succeeded;
            FamilySymbol type = null;
             FilteredElementCollector elemCollector = new FilteredElementCollector(doc);
            elemCollector.OfClass(typeof(FamilySymbol));
            foreach (Element ent in elemCollector)
                FamilySymbol obj = ent as FamilySymbol;
                if (obj.Family.Name.CompareTo("famName") == 0)
                    type = obj;
                    break;
          CreateInstancesOnHostFamilyFaces(type, ins);
I want to place a family at  the center of column's  face.
Kindly help me.
Thanks Advance,
PavelAnd
Hi @Anonymous . You need to use NewFamilyInstance method with reference direction. You can find the example here.
Best regards, Pavel Plotitsyn.
in reply to: PavelAnd
thank u,  but that sample can not help me.
My code    at  beam   and  wall   is  OK!  So, location XYZ  is right.
But  ONLY  at column is  wrong.
I think   column is special.
Organon
@Anonymous ,
Were you able to find a solution to the problem?
Arquitectura | Análisis CAD & BIM | Diseño Paramétrico | Programación
BIM-METADATA | LinkedIn | YouTube
