How to Pick a View using ISelectionFilter
Todd_Jacobs
Todd_Jacobs
Need help creating filter for View
Jim
//Comments removed for brevity
namespace TESTING.View.Select
    public class MySelectView : IExternalCommand
       UIDocument m_document;
       public Autodesk.Revit.UI.Result Execute(Autodesk.Revit.UI.ExternalCommandData commandData,
            ref string message, Autodesk.Revit.DB.ElementSet elements)
            try
                m_document = commandData.Application.ActiveUIDocument;
                Reference viewRef = m_document.Selection.PickObject(ObjectType.Element, new ViewFilter(m_document.Document), "Please pick a View. ESC for cancel.");
                return Result.Succeeded;
            catch (Exceptions.OperationCanceledException)
                // Selection Cancelled. For picking face and picking point.
                return Result.Cancelled;
            catch (System.Exception ex)
                // If any error, give error information and return failed
                message = ex.Message;
                return Result.Failed;
    public class ViewFilter : ISelectionFilter
        Document m_doc = null;
        public ViewFilter(Document doc)
            m_doc = doc;
        public bool AllowElement(Element element)
            return element is Autodesk.Revit.DB.View;
        public bool AllowReference(Reference refer, XYZ point)
            return false;
phildebrandt
What kind of help? Does your code generate an error?
Todd_Jacobs
No runtime error is generated, but when the cursor hovers over a view object it is not allowing it to be selected, the cursor remains as a circle with a slash, I need help with the selection filter code to accept a View object
Jim
Todd_Jacobs
[Edit]
I am not sure if I should be filtering for a View , I did not see a ViewPort class, it's the ViewPort on the sheet which is to be selected
Jim
Todd_Jacobs
I modified the ViewFilter class to this and it seems to work, but is it the correct way of doing it?
Jim
        // Revit document.
        /// <summary>
        /// Constructor the filter and initialize the document.
        /// </summary>
        /// <param name="doc">The document.</param>
            m_doc = doc;
        /// <summary>
        /// Allow View - ViewPort? to be selected
        /// </summary>
        /// <param name="element">A candidate element in selection operation.</param>
        /// <returns>Return true for View - ViewPort?. Return false for non View - ViewPort? element.</returns>
            Reference myView = new Reference(element);
            if (null != myView)
                if ("324" == m_doc.GetElement(myView).GetTypeId().ToString())
                    return true;
                else
                    return false;
            else
                return false;
        /// <summary>
        /// No reference to be selected
        /// </summary>
        /// <param name="refer">A candidate reference in selection operation.</param>
        /// <param name="point">The 3D position of the mouse on the candidate reference.</param>
        /// <returns>Return true for reference. Return false non reference.</returns>
            return true;
