How to Obtain the System Family?
Hi everyone, I want to retrieve the Family of the System Elements (such as for example the "Basic Wall" for a wall), but not only the family name. I want at less the ID of this family. It is posible?
I know that from Symbols families is posible to obtain it. but i think a Wall doesn't have a FamilySymbol.
Mustafa.Salaheldin
Here you are, and please don't forget to mark this reply as an answer if it satisfies your needs
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.ComponentModel;
using System.Collections;
using System.Collections.Generic;
using System.Windows;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
using System.IO;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Events;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.DB.Electrical;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.UI.Events;
using Autodesk.Revit.Exceptions;
using Autodesk.Revit.Utility;
using RvtApplication = Autodesk.Revit.ApplicationServices.Application;
using RvtDocument = Autodesk.Revit.DB.Document;
#endregion
namespace RevitAddinCS2
[Transaction(TransactionMode.Manual)]
[Regeneration(RegenerationOption.Manual)]
public class ExtCmd : IExternalCommand
#region Cached Variables
private static ExternalCommandData _cachedCmdData;
public static UIApplication CachedUiApp
get
return _cachedCmdData.Application;
public static RvtApplication CachedApp
get
return CachedUiApp.Application;
public static RvtDocument CachedDoc
get
return CachedUiApp.ActiveUIDocument.Document;
#endregion
#region IExternalCommand Members
public Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet elemSet)
_cachedCmdData = cmdData;
try
FilteredElementCollector collector = new FilteredElementCollector(CachedDoc);
collector.OfClass(typeof(ElementType));
StringBuilder sb = new StringBuilder();
List<ElementType> ets = collector.Cast<ElementType>().Where(e => e as FamilySymbol == null).OrderBy(f => f.Name).ToList();
foreach (ElementType item in ets)
sb.AppendLine(string.Format("Family Name: {0}, Id: {1}",item.Name,item.Id));
TaskDialog.Show("Revit",sb.ToString());
return Result.Succeeded;
catch (Exception ex)
msg = ex.ToString();
return Result.Failed;
#endregion
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Dear Mustafa.Salaheldin,
thanks for your answer but:
By this way I obtain the Type of the element, but i continue without obtain the Family, only can obtain the family Name (in your code: item.FamilyName). For example for the ElementType Generic - 8", i want the wall Family to which it belongs.
Actually, only can obtain the Name of this family. It is possible to obtain the Family object or, at least, the Id of it?
Revitalizer
Walls are not Family based, thus no Family to get.
They reference a WallType, that is the equivalent to a FamilySymbol.
If there is a project Family, an in-place Family of category "Walls", this is a special kind of "Wall" since it is a FamilyInstance without a WallType assigned, but with FamilySymbol and Family.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
