How to manipulate the Point Cloud imported in Revit using API
Message 1 of 8
Hope you're doing great!
I'd like to manipulate the point cloud imported into Revit using API. For example, I want to find access to the coordinate of points or change their colors. I know how to work with C# and OOP and have already started using SDK to learn the API following the PointCloudEngine sample.  But, in that example, a point cloud is created using generating points along the edges of some cells.
I don't want to create a new point cloud, I just want to have the coordinate of a point cloud that has already been imported into the Revit.
Is there any example that can help me in this regard. Unfortunately, in the Revit API Docs, only the name of classes, methods, and enums have been mentioned and I couldn't find any example on how to use them in my own case.
I would be grateful if somebody could help me a little bit
Kind Regards,
Saeed
Replies (7)
Message 2 of 8
bhprest
Hi there. The Revit API doesn't contain any classes that manipulate point cloud data. However, you should be able to use any .NET-compliant libraries in your addin.
I hope this helps.
Message 3 of 8
Thanks, But how can I at least read the coordinate of points in a Point Cloud after Importing into the Revit? As you know any PC contains coordinate of points. I just want to have access to those coordinates using API.
Message 4 of 8
bhprest
For just iterating through the data, you should be able to use the GetPoints() method on any PointCloudInstance instance.
Check out the example shown here: GetPoints() Method
Message 5 of 8
jeremytammik
Revit includes a Point Cloud Engine API.
The Revit SDK includes a PointCloudEngine sample.
You should definitely take a look at that first of all to understand better how Revit handles point clouds.
Also, of course, as always, it will help a lot to understand the way Revit handles point clouds from an end user point of view before starting to plan any programming task manipulating them.
Here is a pretty old post on the topic:
https://thebuildingcoder.typepad.com/blog/2014/10/point-cloud-indexing-update.html
However, things have evolved quite a bit since then:
https://thebuildingcoder.typepad.com/blog/2017/07/dockable-pane-point-cloud-ai-bim360-forge-and-au.h...
Maybe this more recent post will provide some more productive starting points:
https://thebuildingcoder.typepad.com/blog/2018/09/reality-solutions-sdk-enables-rcp-file-read-write....
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 6 of 8
jeremytammik
By the way, someone elsewhere just pointed out this open source point cloud engine that looks rather impressive at first glance:
https://github.com/potree/potree
Are you aware of that?
Jeremy Tammik
The Building Coder
Message 7 of 8
Thanks a lot for suggesting Potree.
I wasn't; but when you mentioned, I checked it out, and completely know how to implement it now.
Best regards,
Saeed.
Message 8 of 8
jeremytammik
Great! Glad it helped. Thank you for your appreciation.
Jeremy Tammik
The Building Coder
