How to makw WPF with revit
cxyz278
cxyz278
大家好!
我想在Revit中使用按鈕創建一個WPF,但在我創建WPF並將Debug / .exe地址放在PussButtonData中後無法執行。
單擊按鈕後,如何執行Wpf。
 Revit api
#region Namespaces
using System;
using System.Collections.Generic;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using System.Windows.Media.Imaging;
#endregion
namespace RevitAddin4
    class App : IExternalApplication
        public Result OnStartup(UIControlledApplication a)
            RibbonPanel panel = a.CreateRibbonPanel("TEST");
            PushButtonData data = new PushButtonData("ssss", "hello", @"C:\Users\Haseo\source\repos\WpfApp1\WpfApp1\bin\Debug\WpfApp1.exe", "WpfApp1.MainWindow.xaml.cs");
            PushButton button = panel.AddItem(data) as PushButton;
            Uri uri = new Uri(@"C:\Users\Haseo\Pictures\test.jpg");
            BitmapImage largeImage = new BitmapImage(uri);
            button.LargeImage = largeImage;
            return Result.Succeeded;
        public Result OnShutdown(UIControlledApplication a)
WPF
using System;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Navigation;
using System.Windows.Shapes;
namespace WpfApp1
    /// <summary>
    /// MainWindow.xaml 的互動邏輯
    /// </summary>
    public partial class MainWindow : Window
        public MainWindow()
            InitializeComponent();
        private void Button_Click(object sender, RoutedEventArgs e)
            MessageBox.Show("hello");
誰能給我建議?
jeremytammik
BIM.Frankliang
Hi Friend,
     You could do this :
PushButton myButton = CreatePushButton(Panel, "MyFunction", "我的功能");
private PushButton CreatePushButton(RibbonPanel panel, string name, string text)
     if (null == panel)
        return null;
     PushButtonData pushButtonData =  CreatePushButtonData(name, text);
     PushButton pushButton = panel.AddItem(pushButtonData) as PushButton;
     pushButton.LargeImage = LoadImage(name);
     return pushButton;
private PushButtonData CreatePushButtonData(string name, string text)
     if (null == name || null == text)
          return null;
     string assemblyFilePath = Assembly.GetExecutingAssembly().Location;
     string className = $"{assemblyName}.{name}Command";
     PushButtonData pushButtonData = new PushButtonData(name, text, assemblyFilePath, className);
     return pushButtonData;
Then, create corresponding ExternalCommand:
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
[Autodesk.Revit.Attributes.Regeneration(Autodesk.Revit.Attributes.RegenerationOption.Manual)] public class MyFunctionCommand : IExternalCommand
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
var wnd = new MainWindow();
wnd.ShowDialog();
Wish it is helpful 🙂
Best Regards,
Frank Liang
