How to automatically load a Revit plugin?
rita.aguiar
Message 1 of 8
rita.aguiar
I created a Revit plugin with Visual Studio in C#.
How can I automatically load it into the Revit application so that the asking to load dialog (because of an unknown publisher) does not appear?
Is it possible?
 Do I have to use the LoadAddIn method?
Many thanks.
Replies (7)
Message 2 of 8
jeremytammik
Currently, the ultimate source of truth on this topic is this discussion forum thread:
https://forums.autodesk.com/t5/revit-api-forum/code-signing-of-revit-addins/td-p/5981560
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 8
BIM.Frankliang
Dear Friend,
         The load dialog display due to code signature of your revit plug-in. When you finish build or rebuild and then start Revit, it will display to remind you whether load or not load. If you choose "Always Load" and don't build or rebuild your plug-in anymore, it will not appear next time. Wish it is helpful 🙂
Best Regards,
Frank Liang
Message 4 of 8
rita.aguiar
Thank you @BIM.Frankliang.
I wish to implement my plugin in 200+ computers so it's not very feasible to click always load on that many computers.
I am looking for a solution where I can have the plugin automatically loaded without ever asking to load.
Message 5 of 8
rita.aguiar
Thank you @jeremytammik.
Is the only way to automatically load a Revit plugin a Code Signing certificate?
Are there any other options? For example, I have created a very similar plugin for AutoCAD and, to automatically load it, I just had to write an acad and acaddoc lsp files to add the path to the plugin as trusted and to execute the command that initiates the plugin immediately after launch.
I do not wish to publish my plugin on the web. Its just to be used within the several computers of the office I work at.
Clicking on "Always Load" is also not a good option.
Message 6 of 8
jeremytammik
Did you read the thread I pointed out?
I strongly suspect the answer is already given there.
I not, please ask there as well.
I strongly suspect the answer is no.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 7 of 8
rita.aguiar
Yes.
I also found a post where you wrote:
MESSAGE 22 OF 64
"You can sign your own code, and declare yourself trusted to yourself."
How can I do that?
Message 8 of 8
jeremytammik
