How to know the selected element is a void or solid?
hi,
How to know the selected element is a void or solid through API?
Thanks in advance
Hameed
aignatovich
Hi!
If your element is a part of family, such as extrusion, just get BuiltInParameter.ELEMENT_IS_CUTTING value.
If your element is in a project, you should explore JoinGeometryUtils methods, such as AreElementsJoined and IsCuttingElementInJoin
while (eleEnumerator.MoveNext())
Element MyElement = eleEnumerator.Current;
Parameter para = MyElement.get_Parameter(BuiltInParameter.ELEMENT_IS_CUTTING);
The para is null.  I need help
aignatovich
Check the class of your element, I suppose, you work at family editor, so, your element could be GenericForm descendant, if so, it should have such parameters, but your element could be a Model/Detail line or a dimension, for example, you should just skip such elements
Oops.  My element is in project.  I guess i am trying to get the ELEMENT_IS_CUTTING value and it wont work.
How to know the element is solid or not using the JoinGeometryUtils ?
Please help.  I am new to revit API.
aignatovich
Hi!
May be the solution could be something like this:
1) check element class type. Analyze built-in types, for example, if it is Opening, then it is a "cut", return true in such case, if it is not a family instance, then return false (may be there are another cut built-in element types, but I can't imaging anything else now, but it could be false)
at this point you element should be family instance
2) recursively analyze geometry to get all solids with non-zero volume. If there are no solids, it is not either "solid" or "cut", it is just 2d element
3) check solid graphic style, if its property GraphicStyleCategory.Id == new ElementId(BuiltInCategory.OST_IOSCuttingGeometry) than this solid is a cut
If all solids has this graphic style, then your family instance is a void
