How to know if Revit API is in Context.
ricaun
Advisor Advisor
Message 1 of 18
ricaun
After messing with Revit API for so long I figured out a reliable way to know if your code is in Revit API Context or not.
By default, Revit API throws exceptions if your code is trying to execute Revit API methods in a WPF modeless view for example, that's the reason you need to use ExternalEvent to execute Revit API code in context.
Sometimes it is needed to know if the code is running in context or if not, to just execute the Revit API code right away or send it to ExternalEvent to be executed.
If you have access to UIApplication or UIControllerApplication, and if you try to subscribe to an event outside Revit API context you are gonna have this exception: Invalid call to Revit API! Revit is currently not within an API context.
Meaning you could use that to know if your code is in context or not.
Here is a code sample and video: https://ricaun.com/revit-api-context/
I'm this technique using my open-source library to manage the creation of ExternalEvent if it is not in context and enable it to run Revit API asynchronously. https://github.com/ricaun-io/ricaun.Revit.UI.Tasks
I'm planning to create a full tutorial in the future about this library on my YouTube channel.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Replies (17)
Message 2 of 18
moturi.magati.george
Nice work
  Moturi George,     Developer Advocacy and Support,  ADN Open
Message 3 of 18
jeremy_tammik
Shared here on the blog:
https://thebuildingcoder.typepad.com/blog/2024/03/api-context-aps-toolkit-and-da4r-debugging.html#2
Thank you!
Message 4 of 18
nice3point
The Preview version of RevitToolkit provides a way to do this in a more efficient way.
Throwing an exception takes quite a bit of time, and creating additional empty EventHandler<IdlingEventArgs> increases memory allocation.
Toolkit now has Context.IsRevitInApiMode property, that determines whether Revit is in API mode or not
Benchamarks:
IsRevitInApiMode
Exception median: 24122.4 ns
Native median: 413.1 ns
IsRevitOtsideApiMode
Exception median: 9522530.7 ns
Native median: 550 ns
The difference in speed is 58 times in context, and 17313 outside (1000 iterations)
2025.0.2-preview.1.0 is available for testing
https://github.com/Nice3point/RevitToolkit#context
Message 5 of 18
ricaun
Neat!
A method inside the APIUIAPI that does the context check. I wonder what others useful stuff is in that assembly.
Thanks for sharing! 👏
Message 6 of 18
jeremy_tammik
Thank you for discovering and sharing this. Those are impressive results indeed. Shared on the blog as well:
Message 7 of 18
ricaun
Looks like the ActiveAddInId is linked with the Revit API Context.
I never realized it, but the ActiveAddInId is always null when outside the Revit API Context.
bool addInContext = uiapp.ActiveAddInId is not null;
It makes sense that your code would always need an AddIn Context to execute Revit code. Some Revit API methods only allows a specific AddIn to interact, like in the IUpdater and ExtensibleStorage.
I did some benchmark and looks similar like the IsRevitInApiMode implementation. @nice3point how did you create your benchamark, do you have some sample? I did a simple one using Stopwatch.
Message 8 of 18
nice3point
@ricaun
Nice variant, however is it possible to guarantee that this property is 100% context related ? And additionally it requires a reference to the UiAppication.
I'm unlikely to find a benchmark, but yes, I've used StopWatch that way, and additionally 100 iterations on ColdStart ( it doesn't include iteration time in the result), because of the need for Jit compilation, which affects the first startup.
Message 9 of 18
ricaun
@jeremy_tammikcould you confirm with the dev team that the ActiveAddInId is always available when Revit is in context.
I can't think in a example in Revit that is not true.
Only in DA4R that ActiveAddInId is null, but is a bug found recently: https://forums.autodesk.com/t5/revit-api-forum/revit-design-automation-extensible-storage-quot-writi...
Is kinda easy to get the UIApplication especially if you want to run a Revit code, and ActiveAddInId is available in the UIControlledApplication, ControlledApplication and Application.
Nice, I created this test project with all 3 implementations: https://github.com/ricaun-io/RevitTest.InContext.Tests
  • InAddInContext: Using ActiveAddInId
  • InApiMode: Using APIUIAPI
  • InContext:  Using Idling exception
The InAddInContext and InApiMode have a similar time, 0.001 ms to 0.002 ms, and InContext is around 25 to 40 slower.
I gonna try to find some cases to check if ActiveAddInId is available inside Revit events or something, but I'm pretty sure if ActiveAddInId could be use to check the Revit API Context.
Message 10 of 18
nice3point
@ricaun RevitTest.InContext.Tests is a private repository for now, could you open it?
Benchmarks, remember to use Release mode:
public class StartupCommand : ExternalCommand
    private const int ColdStartIterations = 200;
    private const int TargetIterations = 3000;
    private readonly Stopwatch _monitor = new();
    public override void Execute()
        List<Func<bool>> targets =
            IsRevitInApiMode,
            IsAddinActive,
            IsIdling
        Console.WriteLine();
        Console.WriteLine("Inside context");
        ExecuteTargets(targets);
        Console.WriteLine("Outside context");
        Task.Run(() => ExecuteTargets(targets));
    private void ExecuteTargets(List<Func<bool>> targets)
        foreach (var target in targets)
            RunBenchmark(ColdStartIterations, target);
            _monitor.Start();
            RunBenchmark(TargetIterations, target);
            _monitor.Stop();
            Console.WriteLine($"{target.Method.Name}: {_monitor.Elapsed.TotalNanoseconds / TargetIterations} ns.");
            _monitor.Reset();
    private static void RunBenchmark(int iterations, Func<bool> target)
        for (var i = 0; i < iterations; i++)
            try
                target.Invoke();
            catch
                //ignored
    private static bool IsRevitInApiMode()
        return Context.IsRevitInApiMode;
    private static bool IsAddinActive()
        return Context.UiApplication.ActiveAddInId is not null;
    private static bool IsIdling()
        try
            Context.UiApplication.Idling += OnApplicationIdling;
            Context.UiApplication.Idling -= OnApplicationIdling;
            return true;
            void OnApplicationIdling(object sender, Autodesk.Revit.UI.Events.IdlingEventArgs e)
        catch
            return false;
Inside context
IsRevitInApiMode: 277 ns.
IsAddinActive: 465 ns.
IsIdling: 15910 ns.
Outside context
IsRevitInApiMode: 303 ns.
IsAddinActive: 536 ns.
IsIdling: 20945 ns.
Message 11 of 18
jeremy_tammik
Sure; I asked the development team.
Message 12 of 18
ricaun
My bad, I change to public. RevitTest.InContext.Tests
Message 13 of 18
ricaun
I add a test ToolkitTests similar like your StartupCommand but the results looks a little strange. IsRevitInApiMode looks slow.
Inside context
IsRevitInApiMode: 55981.6 ns.
IsAddinActive: 858.6 ns.
IsIdling: 27201.3 ns.
Outside context
IsRevitInApiMode: 52370.4 ns.
IsAddinActive: 756.3 ns.
IsIdling: 33753.9 ns.
Edited: Add link to the ToolkitTests.cs
Message 14 of 18
ricaun
RevitLookUp uses a Toolkit version without IsRevitInApiMode, an exception was happening.
System.MissingMethodException: Method not found: 'Boolean Nice3point.Revit.Toolkit.Context.get_IsRevitInApiMode()'.
Now with the correct version looks better.
Inside context
IsRevitInApiMode: 394.2 ns.
IsAddinActive: 744.7 ns.
IsIdling: 21207.7 ns.
Outside context
IsRevitInApiMode: 379.7 ns.
IsAddinActive: 744.0 ns.
IsIdling: 36853.7 ns.
Message 15 of 18
nice3point
Yes, that's the first thing I thought, Lookup is now using a previous version of Toolkit, you can run the dependency update tool https://github.com/jeremytammik/RevitLookup/issues/269 but I see everything is already in order.
IsRevitInApiMode looks a bit faster because it doesn't contain additional calls to auxiliary functions like ActiveAddin. And if the development team confirms your theory, ActiveAddin may well be used for developers who don't use Toolkit
Message 16 of 18
ricaun
Yes, I just updated manually Nice3point.Revit.Toolkit.dll version in the RevitLookup folder.
The only think I don't like about the IsRevitInApiMode is that uses the APIUIAPI.dll, if was RevitAPI.dll or RevitAPIUI.dll would be perfect.
I hope I'm correct, and is kinda simpler to explain that you need an AddIn Context to run a Revit code, with ActiveAddInId null is kinda obvious that Revit could reject the code without valid AddIn Context.
Message 17 of 18
nice3point
The same thing could be called in RevitAPIUI, but will require more coding, APIUIAPI calls the method directly, with less latency, so this option is more performant and easier to understand for code maintenance
Message 18 of 18
ricaun
Revit AddIn Context is what I'm calling the Revit API Context now.
I tested in a lot of places inside the Revit API and the ActiveAddInId is always valid because Revit tracks what AddInId is executing the code.
Some methods requires to have an AddInId like the Extensible Storage, and when registering a IExternalCommand in a panel the command always generate the same AddInId that was used to register the command.
This is the basic code to check if Revit is in the AddIn Context: https://ricaun.com/revit-addin-context/
bool InAddInContext(UIApplication application)
    // ActiveAddInId is null when invoke outside Revit Api context.
    return application.ActiveAddInId is not null;
There is only one place that the ActiveAddInId is null and Revit API in in Context, inside the Design Automation for Revit event. That's is a bug/limitation and what made me looking in to the ActiveAddInId propriety closer.
And because now I know how the ActiveAddInId works, I can use ExternalService inside Design Automation for Revit to make the event to run in a valid ActiveAddInId.
So I created a library for Design Automation for Revit to fix that and another issue I'm having inside DA4R.
Just need to create a video on YouTube about the package.
