Auto Open Many Previous View When Open Project
ngvanphong2012
ngvanphong2012
I want auto open previous views when open project. Thanks
Mohamed_Arshad
HI @ngvanphong2012
    you need to open all views in the Open Project ?
Mohamed Arshad K
Software Developer (CAD & BIM)
ngvanphong2012
I want Revit to automatically reopen views when closing the previous project. Thanks you.
Mohamed_Arshad
While Closing the Project you need to reopen all the Views of the closing project, I'm right ?
Mohamed Arshad K
ngvanphong2012
That's right, I want to reopen the project views that were closed last time
Mohamed_Arshad
HI @ngvanphong2012
      Yeah Now I get Understand. There is no direct method for that, Below steps are work around steps
  1. First you need to implement two interfaces
    1. DocumentClosing Event
    2. DocumentOpening Event
  2. DocumentClosing Event Implementation
    1. You need to filter all the opened view and save the view names in Extensible Storage within the document.
  3. DocumentOpening Event Implementation
    1. While opening the document you need to check any view names present in the Extensible Storage.
    2. If you get any view names then open the views once document is opened.
By using this two events you can able to do you task. Below i have gave you few links that help you to implement the Revit Events.
Event Implementation Link
https://help.autodesk.com/view/RVT/2024/ESP/?guid=Revit_API_Revit_API_Developers_Guide_Advanced_Topi...
Hope this will Helps 🙂
Mohamed Arshad K
