How to hook on "Reload linked file" event ?
m.vallee
m.vallee
Hi Revit API community,
I want some code to be executed each time the user clicks on "Reload" on a linked file.
I've had a look at PostCommands and Idling events but I haven't find the corresponding "trigger".
How would you do that ?
Thanks for your advice.
BR
Maxime
jeremytammik
Dear Maxime,
Thank you for your query.
I do not think there is a dedicated event to catch that.
Here are some ideas that you might try out:
  • Implement a dynamic model updater, specifying a specific linked file type (or all) as triggers, with ChangeTypeAny.
  • Subscribe to the DocumentChanged event and check whether any recognisable elements get added, deleted or modified when you reload the link.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
m.vallee
Hi Jeremy,
I tried your first idea, as it sounded quite promising.
The resulting behaviour is not far from what I want : my updater is triggered each time a RevitLinkInstance is loaded or unloaded. So if the user clicks on "Reload from", it is executed. But if the user simply clicks on "Reload", nothing happens.
Another point I missed when thinking about the process is that when linked files have been replaced/updated, reopening the main file *does* already refresh all the links, without any user manipulation... how could I detect these changes to execute some code...
m.vallee
Another ideas from the Revit API community ?
Thanks in advance.
BR
Maxime
