Fill Pattern Style
Fill Pattern Style
Fill Pattern Style
I can change the color but I can not change the solid fill style, as I show in the images. Help with this, thank you very much.
this is my code
trans.Start();
ogs.SetProjectionFillPatternId(wall.Id);
ogs.SetProjectionFillPatternVisible(true);
ogs.SetProjectionFillColor(new Color(255, 0, 255));
uiDoc.ActiveView.SetElementOverrides(wall.Id, ogs);
trans.Commit();
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
In the code
To set the projectFillpatternId you need to pass the ID of the fillpatternelement not the Id of the wall.
Filter for the fillpattern you want and pass the id for overriding the graphics settings.
I hope that the below code helps you to achieve this.
FilteredElementCollector Collector = new FilteredElementCollector(doc).OfClass(typeof(FillPatternElement));
                IList<Element> FPES = Collector.ToElements() as IList<Element>;
                FillPatternElement fpe = null;
                foreach(Element e in FPES)
                    if(e.Name.Contains("Your Fill pattern element name"))
                        fpe = e as FillPatternElement;
                OverrideGraphicSettings ORGS = new OverrideGraphicSettings();
                ORGS.SetProjectionFillPatternId(fpe.Id);
                doc.ActiveView.SetElementOverrides(wall.Id, ORGS);
If this helped solve your problem please mark it as solution, so other users can get this solutions as well Smiley Happy
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Thank you for your answer, I was trying to find the solution but I still have not resolved, the sales code error and I can not find the FillPatternElement.  I would appreciate if someone could help me with this
so-chong
As Naveen pointed out you have to pass the Id of the fillpatternelement(fpe).
To set the solid fill style (surface pattern style) you can use the GetFillPattern() method to get the FillPattern associated to this element.
For example, below the inserted code (macro) i choose to set the pattern style to "Crosshatch".
Change whatever pattern style you want to use; only those who are currently available in the project document.
Did you try this something like this?
I hope this is useful for you.
    public void FillPatternWalls()
        UIDocument uidoc = this.ActiveUIDocument;
        Document doc = this.ActiveUIDocument.Document;
        var patternCollector = new FilteredElementCollector(doc);
        patternCollector.OfClass(typeof(FillPatternElement));
        // replace "Crosshatch" with another fill pattern style you want
        FillPatternElement fpe = patternCollector.ToElements().Cast<FillPatternElement>().First(x => x.GetFillPattern().Name == "Crosshatch");
        OverrideGraphicSettings ogs = new OverrideGraphicSettings();
        ogs.SetProjectionFillPatternId(fpe.Id);
        ogs.SetProjectionFillColor(new Color(2550255));
        using (Transaction t = new Transaction(doc, "Set Fill Pattern Walls"))
            t.Start();
                foreach (Element wall in new FilteredElementCollector(doc,doc.ActiveView.Id).OfClass(typeof(Wall)))
                    doc.ActiveView.SetElementOverrides(wall.Id, ogs);
            t.Commit();
        uidoc.RefreshActiveView();
Thank you very much for your answer @so-chong
Greetings,
