How to hide the Text with text type "2.5mm Arial" in the current view using revit api command?
jadhavabhi309
jadhavabhi309
Here is my sample code in python
temp =[]
fec = FilteredElementCollector(doc).OfClass(TextNoteType)#.ToElements()
ElementIDS = fec.ToElementIds()
for i in fec:
    name = i.LookupParameter("Type Name").AsString()
    if name == "2.5mm Arial":
        temp.append(name)
moturi.magati.george
Hi @jadhavabhi309,
To hide elements in Revit, check if the element can be hidden first using  CanBeHidden method
https://www.revitapidocs.com/2015/5e4e0eb6-7328-49b0-d4d0-59729777114d.htm
Then call the HideElements Method to hide the collection of element ids
https://www.revitapidocs.com/2015/6b0ae8d1-776a-ad0d-577d-ffdc11673019.htm
  Moturi George,     Developer Advocacy and Support,  ADN Open
jeremy_tammik
Are you sure you really want to do this? I would assume that there are view settings that can be used to achieve this with less effort and total end user control.
jadhavabhi309
Thank you for responding .What do you mean by view setting and what are they?
jeremy_tammik
https://duckduckgo.com/?q=revit+view+setting
https://help.autodesk.com/view/RVT/2023/ENU/?query=view%20settings
As you can tell from the number of results, this is a rather important and fundamental aspect of using Revit.
I doubt that anyone can use Revit effectively without understanding view settings.
And, as said, it proper use of view settings may enable a much more effective and user-friendly approach to solve your task. Whatever that task may be...
