how to gets relation of element with its tag or its label?
prasannamurumkar
Message 1 of 13
prasannamurumkar
I have doors.
I have door tags
want to verify the whether  particular tags present on that  particular door?
Replies (12)
Message 2 of 13
jeremytammik
Did you RTFM?
https://apidocs.co/apps/revit/2019/759306d1-5168-ef9a-91e4-494c7eff0b5d.htm
TaggedLocalElementId looks like it will do the job.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 3 of 13
jeremytammik
Also, you already asked this same question and received the same answer before:
https://forums.autodesk.com/t5/revit-api-forum/i-want-to-check-whether-tag-is-present-on-door-by-api...
Jeremy Tammik
The Building Coder
Message 4 of 13
prasannamurumkar
At that time i thought that answer is correct but actually answer is wrong.
He answered as tag contains same element  id as that of tag.
but tags are different Id than the element ID
also he  given tags we get like this
var doorTagsIds = new HashSet<ElementId>(collector.OfClass(typeof(IndependentTag)).OfCategory(BuiltInCategory.OST_DoorTags).OfType<IndependentTag>().Select(x => x.GetTaggedLocalElement()?.Id).Where(x => x != null));
 by this not able to collect door tag it just collects id s of door only.
Message 5 of 13
jeremytammik
It collects all independent tags AND the element ids of the doors that they tag.
Jeremy Tammik
The Building Coder
Message 6 of 13
TWhitehead_HED
Hi All,
Given the above property is no longer valid in the current API, what is an updated solution?
Message 7 of 13
jeremy_tammik
I would assume that this can easily be discovered by snooping the element and its tag and their properties using RevitLookup and other Revit BIM database exploration tools. Have you taken a look at that?
Message 8 of 13
jrostar
You could also assume that people come to public forums asking for help after they have already spent time trying to discover the answer themselves and are hoping that knowledgeable people from the community would be willing to help.
Message 9 of 13
jeremy_tammik
Yes, indeed! Sometimes I do, and sometimes they have, and sometimes they have not. It takes all sorts...
Message 10 of 13
TWhitehead_HED
There's a saying about assuming... I'll leave it up to you to find on the internet.
For others scraping through these posts looking for a modicum of actual help, here's how I ended up solving it with help from @Mohamed_Arshad (who actually provided some guidance).
using (Transaction trans = new Transaction(doc, "Tag Parent Doors"))
                trans.Start();
                foreach (FamilyInstance door in doors)
                    if (new FilteredElementCollector(doc, currentView.Id)
                         .Cast<IndependentTag>()
                         .SelectMany(x => x.GetTaggedLocalElementIds())
                         .Where(x => x == door.Id).Any())
                        skipCount++;
                        continue;
Message 11 of 13
DanielKP2Z9V
If anyone lands here looking for a reference how to switch selection between tags and their hosts I have commands to SelectAssociatedTags and SelectElementsHostedBySelectedTags
Message 12 of 13
DanielKP2Z9V
correction, this doesn't seem to work however on rooms and areas - if anyone figured out how to associate room/area tags to their hosts that would be very helpful
Message 13 of 13
jeremy_tammik
Many thanks to Tom, Mohamed and Daniel for digging in and helping with this!
I shared their answers on the blog:
