How to get ViewSets,which i've created in PublishSettings?
I need to get Views ids from created View sets. How can i do that?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
To get view form view set
1)get all the view sheets from the view set.
2)from each viewsheet get the views.
try using the below code
ViewSet myViewSet;
 IList<View> myViews= new List<View>();
foreach(ViewSheet sheet in myViewSet)
                    ISet<ElementId> viewIds = sheet.GetAllPlacedViews() as ISet<ElementId>;
                    foreach(ElementId viewID in viewIds)
                        View v = doc.GetElement(viewID) as View;
                        myViews.Add(v);
Here IList<View> myViews contains all the views placed in the view sheets.
Is this what you want?
If not can you please explain your issue a bit more?
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Thank for your example, but unfortunately it doesn't work,because ViewSet myViewSet is unassigned.
I mean , i need to get Views from ViewSets that are already in the model, not created by myself.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
To collect viewset can you try using the below code
                FilteredElementCollector coll = new FilteredElementCollector(doc).OfClass(typeof(ViewSheetSet));
                List<ViewSheetSet> viewSets = coll.Cast<ViewSheetSet>().ToList();
Naveen Kumar T
I have an error in the  foreach statement .Can't convert from ViewSheetSet to ViewSheet
Thanks a lot, i've done my Task.
			FilteredElementCollector coll = new FilteredElementCollector(currentDocumnet).OfClass(typeof(ViewSheetSet));
			List<ViewSheetSet> viewSheetSet = coll.Cast<ViewSheetSet>().ToList();
			ViewSet viewSet = new ViewSet();
			foreach (var item in viewSheetSet)
				if (item.Name=="NameThatWeNeed")
					viewSet = item.Views;
			IList<View3D> myViews = new List<View3D>();
			foreach (View3D view in viewSet)
				myViews.Add(view);
