Icon button not visible.
mr.engineer.aec
mr.engineer.aec
 Hi guys,
When i debug code add icon button so my icon is not visible on Panel 2.
Panel 1 is split button, they are worked. But Panel 2 is not visible icon. But code by button in panel 2 work exactly
My code under.
How can i solve this issue ?
Thank in advanced.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @mr.engineer.aec ,
I think you should add an image icon to the pushbutton, not to the pushbuttonData.
In your code
 button21.LargeImage = BMI;
replace the above line with this
sb2.LargeImage = BMI;
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
mr.engineer.aec
Hi @naveen.kumar.t
it still not visible icon 😞
naveen.kumar.t
Autodesk Support
Autodesk Support
can you see an image in the pushbutton?
If you can see your image in the pushbutton but the image is not properly visible(or) zoomed in (or) zoomed out then there is a problem with the image pixels.
If you can't see your image in the pushbutton then it is a different issue.
Can you please explain your problem clearly!!!!!
Naveen Kumar T
mr.engineer.aec
 Hi @naveen.kumar.t
Thank for your reply.
With your reply, i changed icon and they work exactly.
Maybe, old icon is error. 😁
