How to get Type Parameters of beam?
I am new to programming Revit APIs, so I would need some help to start. I am trying to create simple API for calculating beams. To do taht I need Beam Type Parameters.
Can anyone tell me how to get Type Parameter, or send me related link ( I can find any).
I suppose code should looks something like this:
        Selection sel = uidoc.Selection;
        Reference pickedRef = null;
        pickedRef = sel.PickObject(ObjectType.Element, "Please select beam");
        Element e = doc.GetElement(pickedRef);
        //don't know which parameter of Element object to use
        double sectionHeight = e.???
Or should I create some other object, not Element object to get Type Parameters?
Milos
Accepted solutions (3)
Revitalizer
an Element's type parameters are in fact its ElementType's instance parameters:
http://forums.autodesk.com/t5/revit-api/reading-instance-parameters-by-api/td-p/5904422
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Thanks! Yes, that was what I did't know.
I supose now I sould select type parameter like this:
        ElementType type = doc.GetElement(e.GetTypeId()) as ElementType;
        BuiltInParameter height = BuiltInParameter.FAMILY_HEIGHT_PARAM;
        Parameter h = type.get_Parameter(height);
But where I try to use that Parameter h, I get null exception, am I missing somthing again?
Revitalizer
Hi MilosNS90,
I would suppose to use RevitLookup to examine the parameters of these objects:
Element e
ElementType type
and, if e is a FamilyInstance and type is a FamilySymbol,
this FamilySymbols's Family also has a set of its own parameters.
If BuiltInParameter.FAMILY_HEIGHT_PARAM is not present, you may find the matching BuiltInParameter this way.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
this would be what I was looking for:
        //to get height of section
        Parameter h = type.LookupParameter("h");
        double height = h.AsDouble();
        //to get width of section
        Parameter b = type.LookupParameter("b");
        double width = b.AsDouble();
        //and so on...
hauvillec
Hi !
I am trying to do the same with a "bathtube" family to get the width and length of it but it's not successful...
Any idea ?
