how to get the pushbutton which i click
//创建Panle
private void CreateRibbonPanel(UIControlledApplication application)
    string tabName = "测绘院工具集";
    string panelName = "测绘院";
    string panelHelperName = "帮助信息";
    application.CreateRibbonTab(tabName);
    #region 孔洞插件
    RibbonPanel panelHole = application.CreateRibbonPanel(tabName, panelName);
    panelHole.Title = "孔洞插件";
    //自动开洞
    PushButtonData btnData1 = new PushButtonData(Properties.Resources.AutoHoleButtonName, Properties.Resources.AutoHoleButtonTitle, AddInPath, "NBGisRevit.NBGisOpeningInWallCommand");
    PushButton button1 = panelHole.AddItem(btnData1) as PushButton;
    button1.ToolTip = "自动开洞";
    button1.LongDescription = "自动开洞";
    button1.LargeImage = CommFunction.GetEmbeddedImage("NBGisRevit.Resources.Icons.qzdkd.png", ImageType.Png);
    #endregion
[Transaction(TransactionMode.Manual)]
[Regeneration(RegenerationOption.Manual)]
public class NBGisOpeningMonitorCommand : IExternalCommand
    public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
        try
            //How to get the PushButton i clicked here?
            return Result.Succeeded;
        catch (Exception ex)
            MessageBox.Show(ex.Message);
            return Result.Failed;
 About is the code , i want to get the button i clicked in the Excute Function,because i want to change the text of the button,so how can i do this?
ollikat
Hi
I think that's not directly possible...at least I couldn't figure out any way. But you could store those button objects somewhere in your application object. Furthermore you could then access / set the text for these buttons via properties/functions of the application class. You just need to figure out some convenient way how to get the instance of the application class within your command class.
Revitalizer
In the TBC blog, you can find this posting:
http://thebuildingcoder.typepad.com/blog/2011/02/pimp-my-autocad-or-revit-ribbon.html
if you scroll downwards, there is this:
Also, an event listener can be achieved for both CAD systems:
ComponentManager.UIElementActivated
  += new EventHandler<Autodesk.Windows
    .UIElementActivatedEventArgs>(
      ComponentManager_UIElementActivated );
void ComponentManager_UIElementActivated(
  object sender,
  Autodesk.Windows.UIElementActivatedEventArgs e )
  // e.UiElement.PersistId says which item has been pressed
This way, you may be notified which button is clicked.
Best regards,
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
