How to get the material's image path or name?
Hi.
In Revit SDK 2015, I want to know, is there any method to get the material's image?
Thank you for any reply.
Revitalizer
there may be a workaround, once invented by myself:
http://thebuildingcoder.typepad.com/blog/2013/07/texture-bitmap-and-uv-coordinates.html
This approach uses a cube, assigns material to it and takes a screen shot, which need to be clipped afterwards to get the desired image.
No code provided, just get the idea.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Hi, Revitalizer.
Thank you for your reply.
It helps me. And I will try this to find out if it works on my project. By the way, I can't find any materils' texture information in RevitLookUp when I select a wall with a texture.
Because I am a beginer in Revit developing, so I want to make sure if I can find any texture information in  RevitLookUp.
Best regards.
Revitalizer
Hi JJLee1024,
the material's texture information is stored in material assets.
These aren't analyzed by RevitLookup so far.
As of now, I haven't found a reliable way to get the texture's image paths (texture map, bump map, alpha map, etc.).
To the wall element and its material(s):
Material can either be defined in the wall's layer, or can be locally overwritten by the paint tool (user can select faces of that wall and assign a diffferent material).
So walls will have several materials in many cases.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Dear Revitalizer
Thank you so much for your patient answer!
This forum is very good and helpful. And I will come back when I get another problem.
Thanks again!
Revitalizer
in the link I pasted into my first answer, CustomExporter is mentioned as a way to get the UV data, the mapping coordinates.
You may have a look at this.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Yeah, I've noticed that and now I am looking up more information about CustomExporter on Jeremy's blog
Thank you for your reminding!
