How to get the Lamp's wattage?
I am trying to read the lamp's wattage,and show it in Addin.
How can I get this data?
Could you please tell me the detail class and member?
Thanks for you very much !
Have you looked in the properties of the light fitting family?
I try to get the wattage from InitialWattageIntensity class's member, Wattage.
But it seems there isn't some method to get the property Wattage.
Could you give me some help?
jeremytammik
Have you looked in the properties of the light fitting family (thanks, Nathan!)?
Have you used RevitLookup to explore the model in depth?
Can you access the desired property through the user interface?
Can you answer any questions at all?
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
I am so sorry to reply latly.
I looked for the light fitting family in Revit API help file, but I can't find it.
Could you please tell me about it a little detailly?
Thanks for you very much!
