How to get the a window outer boundary?
If I have a irregular window like a triangle o trapezoid, How to I can get the outer boundary of that window?
The window can by hosted or not so, the use of some wall as reference for opening is not possible.
I need get the outer boundary used for the family symbol..
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
I hope this link will help you to solve your problem.
find-doors-and-windows-boundary-curves
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Thanks for the tip but I see the topic is using a wall or opening as reference for the calculation and I need get the outer boundary alone, not as reference of a host, opening cut or something else.
Thanks..
Yien_Chao
i can take a look, can you share your window family?
Yes.
Attached is one example of trapezoid window.
I need the outer boundary of the bigger trapezoid only!
Thanks..
