How to get SectionView cropbox?
pochao
pochao
hi there,
I can get ViewSection's BoundingBoxXYZ、 Origin、ViewDirection
But i don't know how to get the CropBox's X,Y (like image dash line)
please help me, thank
jeremytammik
Dear Pochao,
Thank you for your query.
Here is a discussion of creating a section view that is parallel to and exactly aligned with a selected wall:
http://thebuildingcoder.typepad.com/blog/2012/06/create-section-view-parallel-to-wall.html
I also includes retrieving and setting the X and Y extents to size and align the view exactly with the wall.
The crop box is simply attached to the view.
To clarify how to determine the exact crop box X and Y coordinates, this discussion of a Element in View Crop Box Predicate might help:
http://thebuildingcoder.typepad.com/blog/2012/02/element-in-view-crop-box-predicate.html
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
pochao
Dear Jeremy,
thanks for your quickly response.
So i need to use Transform object to get coordinate?
My stupid method:
        Dim bb As BoundingBoxXYZ = MyViewSection.CropBox
        If MyViewSection.ViewDirection.Y = -1 Then 'UP
            minX = MyViewSection.Origin.X - (bb.Max.X - bb.Min.X) / 2
            maxX = MyViewSection.Origin.X + (bb.Max.X - bb.Min.X) / 2
            minY = MyViewSection.Origin.Y
            maxY = MyViewSection.Origin.Y + (bb.Max.Z - bb.Min.Z)
        ElseIf MyViewSection.ViewDirection.Y = 1 Then 'DOWN
            minY = MyViewSection.Origin.Y - (bb.Max.Z - bb.Min.Z)
        ElseIf MyViewSection.ViewDirection.X = -1 Then 'RIGHT
            maxX = MyViewSection.Origin.X + (bb.Max.Z - bb.Min.Z)
            minY = MyViewSection.Origin.Y - (bb.Max.X - bb.Min.X) / 2
            maxY = MyViewSection.Origin.Y + (bb.Max.X - bb.Min.X) / 2
        ElseIf MyViewSection.ViewDirection.X = 1 Then 'LEFT
            minX = MyViewSection.Origin.X - (bb.Max.Z - bb.Min.Z)
        End If
jeremytammik
Dear Pochau,
Thank you for your appreciation.
Just looking at your code I would guess that you want to compare two vectors, e.g. the bounding box Z vector and the view vector, project one onto the other, and determine the resulting X and Y components in some other direction, maybe perpendicular.
Find some ten-year old kid that goes to school and does geometry and vector algebra and ask her:
https://en.wikipedia.org/wiki/Vector_space
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
