Announcements
How to get polygon count of the project ?
I am exporting the model into obj format. I want to know if it is possible to the polygon count or the number of triangles in the model before export. Does Revit provide any API ? Can I count the polygon for a element and then add them all.
Replies (7)
jeremytammik
No, no such API is provided ready-built.
Yes, sure you can retrieve all the element geometry, tessellate it, and sum up the total number of triangles.
You might find it easiest to do so using a custom exporter:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.1
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Homsey-CCH
Export your Revit project (.rvt) or family (.rfa) file to FBX format.  In Revit, go to File > Export > FBX.
Open the FBX file in Microsoft 3D Viewer.  Depending on the file size, it may take a little while to open.  A spinning 3D box icon will indicate loading is in progress.
In the viewer, go to Tools and click on "Stats & Shading".  It will list the number of triangles and vertices.
The 3D Viewer is a free download if you don't already have it in Windows 10.
jeremytammik
Thank you for a non-programmer's answer.
The result should be the same as in using the custom exporter in the Revit API.
Jeremy Tammik
The Building Coder
techXMKH9
Here is the code
class ProfileExport : IExportContext
        private Document document;
        private Func<bool> isCanceled;
        private Action<long, int> callback;
        private long numTriangles;
        private List<ElementId> materialIds;
        private bool includeMaterials = true;
        public ProfileExport(Document document, Func<bool> isCanceled, Action<long, int> callback)
            this.isCanceled = isCanceled;
            this.callback = callback;
            this.document = document;
            this.materialIds = new List<ElementId>();
        public void OnPolymesh(PolymeshTopology polymesh)
            this.numTriangles += (long)polymesh.NumberOfFacets;
        public void Finish()
            this.callback(this.numTriangles, this.materialIds.Count);
        public bool IsCanceled()
            return false;
        public bool Start()
            return true;
        public void OnRPC(RPCNode node)
        public void OnLight(LightNode node)
        public RenderNodeAction OnViewBegin(ViewNode node)
            node.LevelOfDetail = 8;
            return 0;
        public void OnViewEnd(ElementId elementId)
        public RenderNodeAction OnFaceBegin(FaceNode node)
            return 0;
        public void OnFaceEnd(FaceNode node)
        public RenderNodeAction OnElementBegin(ElementId elementId)
            return 0;
        public void OnElementEnd(ElementId elementId)
        public RenderNodeAction OnInstanceBegin(InstanceNode node)
            return 0;
        public void OnInstanceEnd(InstanceNode node)
        public RenderNodeAction OnLinkBegin(LinkNode node)
            return 0;
        public void OnLinkEnd(LinkNode node)
        public void OnMaterial(MaterialNode node)
            if (this.includeMaterials)
                if (node.MaterialId == ElementId.InvalidElementId)
                    return;
                if (this.materialIds.Contains(node.MaterialId))
                    return;
                this.materialIds.Add(node.MaterialId);
jeremy_tammik
Thank you for the nice succinct sample!
I added it to The Building Coder samples in a new external command CmdTriangleCount:
https://github.com/jeremytammik/the_building_coder_samples
https://github.com/jeremytammik/the_building_coder_samples/blob/master/BuildingCoder/BuildingCoder/C...
I tested it in a model with a single wall element with six rectangular faces, i.e., 12 triangles:
As you can see, it reports 36 faces found. Where might the 24 unexpected ones be coming from?
Cheers,
Jeremy
techXMKH9
@jeremy_tammik I do not know why you are getting that. Maybe some hidden elements.
On my end
jeremy_tammik
Thank you for confirming that it works fine for you with no additional filtering.
Maybe the two default levels in my 3D view are contributing something. I'll remove those and try again 🙂
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
