SolidUtils.IntersectSolidWithCurve cutGCurveWithGeometry Exception
MattKincaid
MattKincaid
Sometimes when calling IntersectSolidWithCurve we'll see an error like the one below.
Autodesk.Revit.Exceptions.InternalException
HResult=0x80131500
Message=Error from cutGCurveWithGeometry
Source=RevitAPI
StackTrace:
at Autodesk.Revit.DB.SolidUtils.IntersectSolidWithCurve(Solid solid, Curve curve, SolidCurveIntersectionOptions options)
Does anyone know why this happens? Any workarounds?   I can't find it in the documentation.  It seems to happen most commonly when the curve is nearly coincident with the solid's exterior.
Thanks!
jeremytammik
If you can submit a minimal reproducible case, I'll share that with the development team for analysis:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Afaik, internal exceptions should not leak out into the public API.
Jeremy Tammik
Developer Technical Services
The Building Coder
MattKincaid
Thanks @jeremytammik .  I think I actually discovered the problem.  The solids I was generating to pass into IntersectSolidWithCurve were just degenerate in certain cases.  The solid is created by unioning multiple solids using the BooleanOperationUtils class, but in some cases I was unioning solids when it didn't make sense geometrically.
I refactored my code to make better solids and no more error. Do you think the development team would still want to take a look?  I don't have a good way to provide source code, but I could provide an installer and a sample model.  You could easily decompile.  Let me know if that'd be helpful.
jeremytammik
Dear Matt,
Congratulations on solving the issue and thank you for your appreciation and letting us know.
I think they have more than enough other stuff to keep them well occupied, thank you  🙂
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
DanielNgai
Why i cannot find your class (SolidUtils.IntersectSolidWithCurve()) in Revit API?
MattKincaid
@DanielNgai I don't believe the SolidUtils.IntersectSolidWithCurve() method is in the public API. If memory serves, this InternalException was generated by calling the public API method, Solid.IntersectWithCurve() , and passing a solid with degenerate geometry.
My guess is the public API method calls an internal method, which then generated the exception.  But that's only a guess.  One way to work around the issue is to add a Try Catch, and simply catch the InternalException when it occurs (seems to be rare).
Cheers!
