How to get parameters of a selected Category
dem1st
dem1st
Hi. Selected category is in the variable called "category". Now, how to make a list of parameters that belong to that category and put it inside of a new ComboBox?
Should I create a list of all elements (in Class.cs) inside of that selected category and using foreach get the parameters of every single element (all types of parameters) to later create a collection out of them and finally put it in a new ComboBox?
Class.cs
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.UI.Selection;
namespace CombineParameters
    [Transaction(TransactionMode.Manual)]
    [RegenerationAttribute(RegenerationOption.Manual)]
    public class Class : IExternalCommand
        public Result Execute(ExternalCommandData commandData,
                              ref string message,
                              ElementSet elements)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Document doc = uidoc.Document;
            Settings documentSettings = doc.Settings;
            Categories categories = documentSettings.Categories;
            SortedList<string, Category> myCategories = new SortedList<string, Category>();
            foreach (Category c in categories)
                myCategories.Add(c.Name, c);
            myCategories.Clear();
                if (c.AllowsBoundParameters)
            UserWindow UserWindow = new UserWindow(myCategories);
            UserWindow.Show();
            ElementCategoryFilter filter = new ElementCategoryFilter(category);
            FilteredElementCollector collector = new FilteredElementCollector(doc);
            IList<Element> ListOfParameters = collector.WherePasses(filter);
            //this one doesn't work either
            //IList<Element> ListOfParameters = ListOfParameters.OfClass(typeof(category))
            return Result.Succeeded;
UserWindow.xaml.cs
using System;
using System.Linq;
using System.Text;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using System.Windows.Navigation;
using System.Windows.Shapes;
    /// <summary>
    /// Interaction logic for UserWindRoom.xaml
    /// </summary>
    public partial class UserWindow : Window
        SortedList<string, Category> myCategories;
        public UserWindow(SortedList<string, Category> elements)
            InitializeComponent();
            AllTheCategories.ItemsSource = elements;
            AllTheCategories.DisplayMemberPath = "Key";
            AllTheCategories.SelectionChanged += OnSelectionChanged;
        public void OnSelectionChanged(object sender, SelectionChangedEventArgs e)
            if (AllTheCategories.SelectedItem is null)
            else if (AllTheCategories.SelectedItem is KeyValuePair<string, object> keyValuePair)
                var category = (Category)keyValuePair.Value;
Some parameters are generic across all elements that are non-annotative for example.
BuiltInParameter.ALL_MODEL_TYPE_COMMENTS
BuiltInParameter.ALL_MODEL_MANUFACTURER
BuiltInParameter.ALL_MODEL_DESCRIPTION
BuiltInParameter.ALL_MODEL_FAMILY_NAME
But for user-created parameters, you will need to unpack them from the projectparamterbinding.
You can do it in Jeremy's post here:
https://thebuildingcoder.typepad.com/blog/2015/12/shared-project-parameter-guid-reporter.html
Cheers,
J.
