Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to get dimensions from sketch??
4 REPLIES 4
659 Views, 4 Replies
hi
i need to get dimensions from sketch
here is the code
Element e1 = (Element)Fmly;
ElementId eid = e1.Id;
Transaction t = new Transaction(doc, "fake");
t.Start();
ICollection<ElementId> ids = doc.Delete(eid);
t.RollBack();
foreach (ElementId id in ids)
Element ele = doc.GetElement(id);
string name = ele.Name;
list1.Add(name);
if (ele is Sketch)
Sketch s = (Sketch)ele;
string name4 = ele.Name;
SketchPlane sp = (SketchPlane)doc.GetElement(name4);
CurveArrArray caa = s.Profile;
foreach (CurveArray ca in caa)
foreach (Curve c in ca)
else if (ele is Dimension)
Dimension d = (Dimension)ele;
string dname = d.Name;
string dvalue = d.Value.ToString();
hi
here is the code
t.Start();
t.RollBack();
list1.Add(name);
if (ele is Sketch)
4 REPLIES 4
aignatovich
aignatovich
Hi! The idea of an element deletion + temporary transaction seems good for me. But source element must have a sketch in such case, e.g. source element should be a Floor, for example.
I think you need to improve your code: first of all, find sketch in ids list, get all model curves references, then find dimensions in this list and filter them - sketch dimensions must have references to sketch model curves (just compare stable representations)
in reply to: aignatovich
hi
i am looking to get the sweep/extrusion pathsketch dimensions.
first i am getting the sweep profile and then traversing the curves in the profile..apparently i am getting the wrong dimensions
can you help me out here??
where am i wrong??
Transaction t = new Transaction(doc, "GetElementId's");
t.Start();
t.RollBack();
List<string> sweeplist = new List<string>();
list1.Add(name);
if (ele is Sweep)
Sweep s1 = (Sweep)ele;
Sketch s2 = s1.PathSketch;
SketchPlane sp = s2.SketchPlane;
CurveArrArray caa = s2.;
string cleng = c.Length.ToString();
hi
where am i wrong??
t.Start();
t.RollBack();
list1.Add(name);
if (ele is Sweep)
aignatovich
aignatovich
I'm not sure about what you want to achieve.
Perhaps, this will help you:
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
	var uiapp = commandData.Application;
	var uidoc = uiapp.ActiveUIDocument;
	var doc = uidoc.Document;
	var collector = new FilteredElementCollector(doc);
	var sweep = (Sweep) collector
		.OfClass(typeof (Sweep))
		.FirstElement();
	var profileCurves = sweep
		.ProfileSketch
		.Profile
		.Cast<CurveArray>()
		.SelectMany(x => x.Cast<Curve>());
	TaskDialog.Show("dev", $"Profile curves length: {UnitUtils.ConvertFromInternalUnits(profileCurves.Sum(x => x.Length), DisplayUnitType.DUT_MILLIMETERS)} mm");
	return Result.Succeeded;
		.FirstElement();
		.ProfileSketch
		.Profile
		.Cast<CurveArray>()
hi
thank you  @aignatovich  for this. i didn't see the units. when i run my code the length is not in mm..
so thanks for helping me out.
hi
