How to Fix the Infamous "Can't create stairs" Error for Custom L-Shaped Winders (Sketch Method Guide)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey everyone, I wanted to share a quick workflow fix for a frustrating issue that comes up a lot when designing custom architectural stairs, especially monolithic ones with L-shaped starting steps or unique winder configurations.
A lot of users run into the dreaded "Can't create stairs" error when they try to force Revit's automatic Straight Run component to bend into an L-shape at the base. Revit's default stair engine just can't process overlapping risers and custom boundaries that way. To get a clean, continuous monolithic look where the first few steps wrap around a corner, you have to bypass the automatic run and use the manual sketch method.
Here is the exact step-by-step breakdown to get it right without the geometry breaking:
First, clear out any failed automatic runs, select the Stair tool, and click on Create Sketch (the pencil icon). This opens up the free-form drawing mode where you control the boundaries, risers, and path manually.
Start with the Boundary lines green Draw the outer and inner perimeter lines of your staircase. The absolute golden rule here is that boundary lines must only run along the sides of the stairs; they should never cross over the front of a step. For an L-shape base, your green boundary line needs to cleanly follow the outer and inner corners of that turn without interruption.
Next, switch to the Riser tool black/grey lines Manually draw your first two steps as L-shapes. It is critical that every single riser line perfectly snaps to the green boundary lines on both ends. If there is even a millimeter of a gap, or if the lines overshoot and cross over each other, Revit's calculation engine will throw an error and fail to generate the geometry.
Finally, use the Stair Path tool to draw a continuous blue line starting from the very first riser all the way to the top step, crossing through every single riser line perpendicularly to define the direction of travel.
Pro-Tip for Monolithic Type Stairs
Sometimes, even with a perfect sketch, Revit's automatic concrete underside (soffit) can look a bit warped or distorted around a custom L-turn. If the structural concrete thickness doesn't look right under those first two steps, a common industry workaround is to model the custom L-shaped base separately using an In-Place Component Generic Models, and then start your actual Revit stair run seamlessly from the third step upward.
Hope this helps anyone struggling with custom stair geometry! Let me know if you run into any calculation issues with this method.
